Hello,
I have a few issues with my Berlina:
http://imgur.com/efeZT.jpg
http://imgur.com/x25Jo.jpg
My first problem is with the centre console compartment. As you can see it is scratched up and one of the hinges is brocken so I would like to either replace it with the same one or with a a cupholder compartment that is seen in other models.
The only problem is I do not know how to remove it or replace it. I'm trying to find some instructions on how to do so and where I can find someone that is selling the parts I need.
My next problem is with an old Nokia handsfree phone cradle and kit. It has a speaker and box buried somewhere in the dash. I removed some of the cadle and tucked the connectors under the plastic panels. I kept the passive antenna cable incase I could use it for my iPhone (passively). I'd like to remove this as well, but don't know to remove all the panels.
http://imgur.com/zCRnm.jpg
The next couple of pictures are of the door rubber seal and the drivers side carpet where the left heel digs into it. Has anyone got any good fixes for these?
http://imgur.com/F0OEG.jpg
http://imgur.com/RqMuy.jpg
Thanks for your help in advance!![]()
to remove the handsfree kit thing, open the glovebox, and you'll see next to the boot release button a screw and follow that down, theres another screw, undo them and carefully but sternly bend the plastic so it can pass the glovebox and you can remove the handsfree easily.
Thanks for your help guys,
Today I successfully removed the Nokia HFU-4 car kit completely and without damage, I am now going to sell it on eBay since I have an iPhone now.
I also took a few pictures of the damaged mechanism on the centre console compartment. It's just missing a peice of plastic that acts like a hinge that should connect to a spring. I still have the spring and axel for it however, it looks like i'll need to buy a new lid from somewhere to fix it.
I also noticed that there were a few differences with my car and that dash removal guide posted above.
http://imgur.com/oLrEK.jpg
http://imgur.com/7JjK3.jpg
http://imgur.com/H5Ehh.jpg
http://imgur.com/uqYZq.jpg
http://imgur.com/zTJ98.jpg
http://imgur.com/ZATi5.jpg
