Results 1 to 23 of 23
Thread: Miss at idle and a few other things.
    vy commohore
    Mar 2008
    Default Miss at idle and a few other things.
    Hi all,
    I have an ex cop VYII done 280000kms, Here are a few issues i have had, Door lock actuators failed, I have removed them, dismantled, cleaned motor commutator/brushes, and fitted new microswitches (although they tested allright) That fixed the prob, Its a bit off a mission but being a tight arse I hate paying for anything!!
    My diff makes a horrible clunking noise when coasting, accelerating and decelerating, checked drive train and there is no play, so it is in the diff somewhere.
    The stereo turns on by itself (sometimes) after exiting the vehicle, thats an easy fix, I have to turn it off manually before getting out.
    Steering "shudders" at low RPM (at turning extremes) , I have read that this is because hydraulic hoses are too small in diameter and fixed by installing larger diameter hoses, I can live with that though.
    I now have a miss at idle ( I can feel it up to about 2000RPM) The fault started intermittently, but now is there all the time. The exhaust smells really rich and I am using more fuel. (15ltrs+ per 100kms) around town. Also it is hard to start sometimes, hot or cold. It accelerates perfectly throughout the rev range (once past 2000rpm), but misses when coasting at 50kms (revs at 1500rpm). It stalls sometimes too. I have renewed the spark plugs and checked all vac hoses, injectors, leads, sensors ( new O2 sensors), Cleaned the throttle body, IAC and TPS. I cannot isolate a single cylinder miss, it seems to be missing on all cylinders. I have sprayed water all over intake manifolds and not got a drop in RPMs so effectively ruling out an induction leak. I cannot check the EGR valve, nothing in the manual about a testing procedure. I cannot get the purge valve solenoid to actuate when applying 12 volts ( I turn ignition on, there is 12 volts at the plug but when i connect/disconnect the plug nothing happens) I have bypassed it and still the same miss. There are no faults logged, and the check eng light has not illuminated. I am guilty of occasionally running it on a mix of avgas and unleaded! ( i get small amounts for free ) This might have something to do with it , but in my experience, higher octane fuel will affect the O2 sensors and the cat convertor, both of which seem fine. I am not sure if it would affect charcoal filter though. Well thats about it, anything I have missed?? I am thinking The ignition unit under coils or mixture problem. Thanks guys.
    VY Ex-cop
    Mar 2006
    sounds like the classic dirty injector problem. at 280k if they havent been replaced they are sure overdue. this will fix alot of idling issues
    vy commohore
    Mar 2008
    Thanks for a quick reply theICEMAN
    I might try some injector cleaner then??
    The pump is working, and the filter is not blocked.
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    prob want to get them properly cleaned and tested. i had 1 quote for $110 to do it all pro. i've prob nearly spent more than that on bottles of injector cleaner with no results.
    i herd it keeps good injectors clean, but wont fix a dirty or clogged injector.
    VY Ex-cop
    Mar 2006
    thats it, injector cleaner wont clean dirty injectors and is a waste of cash. they sell sets of cleaned up injectors for V6's on ebay for around $100.
    replace injectors, if its still running like crap get it looked it.
    Sep 2009
    goldcoast
    vy commohore
    Mar 2008
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by gherb View Post
    Thanks guys,
    Will try some injectors then, will keep you posted
    youll have to pay for this one, you cant clean them yourself any cheaper. (referring to your first post)
    vy commohore
    Mar 2008
    Just got my injectors checked and cleaned today by a friend of mine, he said they were in great condition and flow checked well. refitted them but the miss is still there I removed my MAF sensor and cleaned with brake cleaner but made no difference. I fitted new leads yesterday as I saw some flashover between leads but no improvement on idle miss. I am running out of options.. any more ideas???
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Have you replaced the coil packs? That and check the gap on your spark plugs - one of mine wasn't correctly gapped out of the box so it missed occasionallly
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Sep 2009
    goldcoast
    haa what a bitch, i'm getting new injectors on monday, but you just killed all my hope's of it solving my little miss. seems pretty similar to yours, upto about 2000rpm/slight bit of throttle/bairly noticable but still annoying.
    i've try'd different coil packs and made no difference at all, changed the plug gaps a number of times but no joy from that either,and a different tune but still no go. i've been thinking mayb its the lim gasket leaking but not to keen on changing it yet.
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    vy commohore
    Mar 2008
    Yep I have checked the plug gaps twice!
    I havnt tried new coils yet but a friend of mine just brought a VT wagon, so I might try swapping some
    bits over if they are compatible. Will keep you posted.
    Wana s'charge.... whats the Lim gasket?? lower intake manifold?? I have tightened my intake bolts, they all were a little bit loose. It does feel like an induction leak I just cant find it. Damn thing is stalling more often now.
    Sep 2009
    goldcoast
    yeah, lower intake manifold. if you havent already, while its idling you can spray water/carbi cleaner/throttle body cleaner, ect around the manifold join,injectors,hose joins or anywhere where it could leak air from and it 'should' suck it in and change the rev's a bit. i havent had any luck with it thou, but been told it works.
    and the coils will be the same, try n swap the whole lot, (coils and dfi plate under it)
    ya dont have a little bit of oily crap under radiator cap do ya ????(another sign of lim gasket gone)
    vy commohore
    Mar 2008
    yep I have tried spraying water around and no drop in Revs, I tried removing fuel regulator hose from back of plenum to see if there was fuel in the line (indicating leaky diaphragm) but it was dry, it did seem to run a tiny bit smoother when i plugged hole in plenum though. I would like to check fuel pressure at rail to verify correct op of regulator. My radiator cap is mint, no sludgy crap or anything,..
  15. #15
    Sep 2009
    goldcoast
    sh!t hey, what a pain.
    lol i just ended up convincing myself that its ment to run like that and gave up for a couple of months,was over it, and was hoping whatever it is would just sh!t it self completely so i could pick what was wrong. .
    i've never tested the fuel pressure/reg properly thou, disonected it the same like you said but had no leaks.. it didnt change the revs at all thou, i thought it's ment to run rougher when vac lines disconnected from fuel reg..
    (just a thought/theory) but may have to higher pressure at low rpm and with stuff all throttle, and could cause it to flood it a bit and slightly miss, run rich, use alot of fuel)
  16. #16
    Sep 2009
    goldcoast
    i've also got 1 funny plug, no.5. its got a little burn mark on the white ceramic bit and keeps happening. (hoping its the injectors)
    are all your plugs the same???????
  17. #17
    vy commohore
    Mar 2008
    When i unplugged regulator vacuum hose the revs increased due to intake port open to atmosphere, leaning the mixture, and decreased and ran a bit smoother when i plugged the port with my finger. I spose you could muck around with regulator by applying vacuum with vac pump if you have one ( i dont) But as there is high pressure in the line it might damage something else in the fuel system. All my spark plugs are new last week, have changed them twice in the last month, they all looked good.
  18. #18
    Sep 2009
    goldcoast
    for farrrrrrrrkkkkk sake, i got the new injectors in today but now if its been sitting for a while it will turn over for 3-5 sec's befor it starts. but if turn it off and on again it starts straight away. and got a little bit of pinging back again. yay
    its like its not building enough pressure for some reason if ya leave it sit for a bit.
    changed the fuel filter today too, anyone had the same problem???????????????
    really really getting the shits with it now. ,
  19. #19
    Sep 2009
    goldcoast
    if ya end up getting a new fuel reg try holden first. i'm getting one off them for $68. bursons or global wanted around $160 (for super6 reg anyway)
  20. #20
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Quote Originally Posted by wana s' charge stock vt View Post
    I've had this on no.5 plug too - little black build up on white ceramic. Plugs on 1 month old , and have replaced no.5 plug again but still doing it a bit. Motor runs/idles mint! Any ideas??
    When I did plugs I also did O2 sensors and just replaced leads today. Done 200,000 km
  21. #21
    vy commohore
    Mar 2008
    Default yay finally fixed it
    Well guys after swapping over the coil packs and trying another IAC valve and TPS I took the car into holden. I told them all the work I had done and they rang me 2 hours later saying they had found the prob ......
    A stuck EGR valve!!!!!!
    The manual says you cant test them so I didnt bother, Got another 1 second hand for $200 NZ. Going to pick the car up after work tonight.
    Well done Robertson Holden.
  22. #22
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Huh $200? Guy at Holden quoted me $100 for a genuine new one.
    Ronald Reagan (1986)
  23. #23
    vy commohore
    Mar 2008
    They quoted me $800 for brand new holden EGR valve, managed to get one for $250, I dont really care now cause I,ve got my car back and after everything I have done its running awesome! I forgot what Its suppose to run like. You wouldn't even know the car is running at idle its sooo smooth. I will do a bit of research on this though, thanks for the headsup.
  1. tiny miss on idle
    By vn_v6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2010, 10:12 PM
  2. vr v6 slight miss at idle
    By 94vrcaprice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2010, 01:29 PM
  3. bad miss rough idle
    By STYALR in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2006, 04:46 PM
  4. Vp bad miss at idle
    By gr8304_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 07:47 PM
  5. Miss At Idle
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 09:07 PM
