Results 1 to 4 of 4
Thread: Bleeding the Clutch on a VY SS Manual Ute
    VY SS Ute 5.7 M6
    Jul 2010
    Default Bleeding the Clutch on a VY SS Manual Ute
    Could anyone please tell me how to bleed the clutch on my VY SS Manual Ute. I have had the NRMA out this morning and they have confirmed that it just needed a top up of fluid, however the line now needs to be bled.
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    You will need help as one will have to loosen the bleed nipple on the clutch actuator the other pushing on the clutch pedal.. Just like bleeding brakes but without the fear of stuffing up ya ABS :P
    Cheers,
    Dave
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Replacing the clutch fluid is made a little tricky because of the location of the bleed nipple on the slave cylinder which is inside the bell housing. Best suggestion is to install an Xtreme Extended Clutch Bleeder part number CSCGM011-EXTBL. I purchased one recently from Bursons for $17. Remove the old bleeder by using double sided tape inside a long 7/16" socket (to make sure the old one doesn't slip inside the bell housing). Slide in the extended bleeder and make sure you fully tighten the new bleeder before loosening it slightly for the bleed. It winds in quite a long way. You can then bleed the clutch in the same way as you do brakes - siphon out the old fluid from the clutch master cylinder (I use a turkey baster !!!), mop the remaining junk out of the master cylinder using a rag or kitchen paper, fill with new fluid and bleed. Make sure you keep up the fluid level in the master cylinder because the capacity of the cylinder is only sufficient for about three pumps of the clutch pedal.
    VY SS
    May 2011
    Auckland
    Hey all.
    My clutch fluid looks black and has lumps (apparently this means slave or master cylinder could by on it's way out). How hard is it to get to the bleed nipple and where is the access? Drivers or passenger side, top bottom etc
    Thanks in advance
  1. Vt manual clutch adjustment???!?!?
    By LOWPACK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2010, 07:36 PM
  2. Manual gearbox/clutch help
    By sweefu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2009, 12:49 PM
  3. Bleeding vx ss clutch line
    By Smashn2nd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2009, 01:45 AM
  4. Clutch Bleeding issues
    By the_duke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 10:53 PM
  5. Gearbox / Clutch Manual T5 - PLEASE HELP
    By CMI83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2006, 10:53 AM
