at the moment the ute has standard suspension and sits heaps high been looking on ebay for springs that lower 50 -60 mm does any one know if i can just buy the spring to lower or will i need the shocks to go with the springs.i dont really want to spend to much or will i have to???
youd probably want shorter shocks as well to stop ya new lower spring falling out when ya run over bumps and sending you into a tree sideways.
and also a rear camber kit if your going low, so you dont wear the tyres as bad on the inside![]()
do utes have IRS? ive never noticed, didnt think they did. if it hasnt, dont need camber kit.
just get some superlows should be around 300 fitted wont need camber kit or shortend shocks
i just lowered my vy ute. i put kingspring superlows in the back and kingspring lows in the front and my car rides and looks alot better. i payed $300 for both sets of springs together from repco.
