Results 1 to 5 of 5
Thread: is it possible to put fog lights here?
    Sep 2007
    Default is it possible to put fog lights here?
    i have a pic here to show you where i mean, If i can how do i go about it?
    http://i280.photobucket.com/albums/k...t/Untitled.png
    VY Executive S2
    Jan 2010
    Sep 2007
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Neppirt
    Fitting foggies in there is pretty straightforward but would require a great deal of farting around making up mounting brackets.
    You would need to remove the bumper and use angle brackets mounted under the reinforcement bar, placing the lights so that they are equally mounted for distance from the car centreline, height and depth, then cut the holes into the clip-in inserts. Your mountings would need to provide adjustment so that the lights can be adjusted to centre them in the grille inserts. I had to do this when I replaced the Berlina lower grille with a Series 2 Calais one. The new grille didn't have any mounting points so I had to make them up as described above.
    Then you have the wiring to consider and the Exec won't have any pre-installed wiring, so you need to fit the whole circuit, switch, relay etc.
    Quite feasible, but a lot of work.
    Sep 2007
    Thanks heaps mate
  1. Changing VE sv6 lights to HSV lights. any problems with projector lights
    By SV6.VICTORIA in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-06-2011, 01:39 PM
  2. Replies: 21
    Last Post: 22-06-2010, 10:35 PM
  3. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  4. Replies: 3
    Last Post: 26-10-2006, 05:43 PM
  5. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
