Results 1 to 17 of 17
Thread: Should i upgrade exhaust? Anyone done the same as me on a V6?
    VY Commodore 04 series II Executive
    Jun 2010
    Default Should i upgrade exhaust? Anyone done the same as me on a V6?
    My first car(grey V6 3.8L VY executive series 2) is nice but im a little dissapointed on the pick up so i was looking to upgrade the exhaust as i have been told that it is the best bang for buck as far as increased power but i have also read that it will mess with the ECU and i wont get any power maybe even a drop in power? If anyones had any experience or works in the trade of exhausts or whatever could you drop me a line cos i want it done soon.
    Extra info: Been quoted between $450 and $550 installed good price?
    Also been told 2.5" exhaust is best is this true?
    Car is stock excluding 18" rims and stereo
    Thanks
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Exhaust probably won't make much of an increase at all. You want bang-for-buck then go some higher ratio rockers.
    Ronald Reagan (1986)
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Exhaust does shit all really, High ratio rockers are the best bet.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Yep - exhaust will give you fun from a better note, with a CAI might give you the illusion of more power..
    Go for a major service, including gearbox to make it feel good to drive.
    Then i'd agree go for some high ratio rockers.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VY Exec s2 3.8L
    Jun 2010
    I put 2 1/2" from cat back on mine. sounds pretty good. Got it on the dyno before a major service and got steady 175kw readings so slight power increase.
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    if you want a nice sound, go 2 1/2inch. i'd get the zorst done then a tune. then some high ratio rockers
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VX Berlina
    Apr 2007
    Quote Originally Posted by Dethadder VY View Post
    How did you get 175kw reading? Take engine out and put it on engine dyno?
    Dec 2009
    My view, the standard exhaust is good enough and it's made from stainless, why spend that sort of money to make the car noisy and replace something that will last the life of the car with something that will rust out in a few years.
    As well as the higher ratio rockers you could consider a heat insulator spacer between the plenum and inlet manifold. I have read that these offer a cost effective performance gain on their own. I'd also be leaving the airbox pretty much as it is and just use stock elements and change them mor eoften if you want to.
    Mar 2008
    No, just no. 25ish kw from an exhaust?
    Quote Originally Posted by wortus View Post
    I can back the insulators 100%. You'd be surprised at how much torque you gain from these things.
    VX Berlina
    Apr 2007
    Quote Originally Posted by one_and_only2004 View Post
    But,but,but thats what the brochure said!!! LOL.
    Just like my 10kW air filter, and my 15kW CAI.
    And to 'Dethadder VY' I would be doing the service before the dyno. When they are revving the tits off your car you want good oil in there not oil at the end of its life.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    It's a waste of money messing with the exhaust. At legal road speeds you will not notice nay difference at all other than the noise.
    As others have said, have the car properly serviced so the motor is running at its optimum. Maybe new plugs and leads if necessary. Change the air cleaner element. It's probably clogged anyway and thus impairing inbound airflow and reducing performance. (That will cots you a massive 12 dollars). Fresh engine oil and filter etc etc.
    When the engine is running at its optimum there is plenty of power and torque in these V6 motors.
    Get the compression checked in all cylinders.
    If you have got a high km worn out engine with poor compression readings you are not going to get performance by sticking an aftermarket exhaust on it.
    VY Exec s2 3.8L
    Jun 2010
    Quote Originally Posted by acarmody View Post
    yeah got that wrong lol. 175hp sound a bit more realistic? factory about 152. they had a big fan blowing straight onto the front of the car and was a cold night, maybe that worked in my favor.
    but yeah. deffinatly not 175kw, would be nice though
    had done a oil change about 10,000k's before that so still pretty good oil running through.
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Is that in a manual? is the car stock apart from the exhaust?
  15. #15
    VY Exec s2 3.8L
    Jun 2010
    The car has a auto and as far as i know the motor is stock, was ex gov company vehicle. had a pod on it at the time. Heres a pic of the . dyno chart
  16. #16
    Mar 2008
    If that's 175hp at the wheels, you my friend have an awesome vy!
  17. #17
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    ^^ lol happy dyno. Stock V6 makes 110kw (147hp) at the rears.
    Major service, push the pedal harder, better tyres and remove excess weight from the car.
    All modifications that increase power rob torque... apart from a supercharger.
  1. exhaust upgrade
    By glenny1988 in forum TTT Performance Engineering
    Last Post: 27-10-2010, 05:54 PM
  2. Exhaust Upgrade
    By AndyVE in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-11-2009, 06:25 PM
  3. what exhaust to upgrade to
    By vpcommo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2009, 03:08 PM
  4. Exhaust Upgrade for VP V6?
    By thehsvmanv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2006, 07:14 PM
  5. vs v8 exhaust upgrade?
    By matty,vs,ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2004, 03:31 PM
Tags for this Thread
