Results 1 to 10 of 10
Thread: draining power?!?!?!
    VY EXECUTIVE Series II
    Feb 2010
    Default draining power?!?!?!
    Hi guys, I have a slight problem with the power??
    Started off with doing some maintainance on the car on a saturday. I didnt turn it on until monday morning... (not a long time)...on monday when I tryed to turn the car on I couldnt so i had to jumpstart the bugger
    some things i have is 6 disk stacker (no problems)
    3 blown speakers
    nothing else, no lights staying on nothing......???
    anyone else have battery draining problems?!!??
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    1. Possible culprits:
    Poorly wired aftermarket sound systems if fitted;
    Front Seat motors not shutting off and drawing power (check the electric motor in the driver's seat) ;
    Faulty power window switch not shutting off power;
    Motor in a power window not shutting down;
    Faulty after market alarm systems if fitted.
    I assume you have a healthy battery. If it is over 3 years old it may be on it's last legs so get that checked also.
    2. Now that the battery has been discharged, make sure to disconnect the battery and give it a full re-charge.
    evl55 is offline evl55
    vy ss ute
    Feb 2008
    is it sedan??? maybe you left the boot ajar? ive done this before and its amazing how a boot light can draw that much power
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Feb 2010
    sedan
    no aftermarket sound system, the boot latch light turns off (all lights are turned off) brand new battery has been fully charged, took out the seat fuses, no alarm sys installed, window switch and window motors are in perfect nick and the light switch is set to O not auto.
    i wouldnt have a clue whats draining the power ??
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    bad earth somewhere. may have knocked a earth while you were working on the car.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    Feb 2010
    I woudnt know about that kingston if i was doing oil change and took the driver seat out....
    May 2009
    VIC / NSW
    Quote Originally Posted by romojohnny View Post
    sedan
    No aftermarket sound system, the boot latch light turns off (all lights are turned off), brand new battery has been fully charged, took out the seat fuses, no alarm system installed, window switch and window motors are in perfect nick and the light switch is set to O not auto.
    I wouldn't have a clue whats draining the power ?
    It's time for a visit to your friendly auto electrician to trace the fault for you.
    VY Exec & VZ Calais
    Mar 2010
    Not sure on what it could be, but above posts say boot light etc, Doesn't the boot, interior glove box etc. lights turn off after an hour?? I've left my boot wide open and after a while the light is off. I think VY/VZ this is a feature on all. Could be a fault in the BCM??
    Hope you get it sorted soon mate.
    Feb 2010
    yeah thnx guys only chance is to go to an auto electrician and see what & where the fault is.......this BCM i always hear about can someone tell me whats the function and where found??? i know it means Body Control Module but dont know too much about it?
  1. Calais headlight.. draining power
    By VLC86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-05-2010, 11:33 PM
  2. faulty computer draining power
    By VL Berlina 5speed in forum Electrical Wiring / Questions
    Last Post: 16-03-2009, 03:41 PM
  3. Subs draining TOO much power...
    By botchla90393 in forum Car Audio
    Last Post: 18-09-2008, 09:01 AM
  4. Tacho seems to be draining power...
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2006, 05:22 PM
  5. Power draining,advice plz
    By shellw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2006, 08:57 PM
