does anyone know where the fuel pumps are located????
Remove the left side front floor panel in the tray to access the tank and to disconnect the harness, remove the left side panel at the back of the cabin. Don't forget to pull the pump relay and run the engine till it stall's to take the pressure out of the line ect.
Cheers,
Dave
Yeah mine was in the tray, just pull out the big bloody panel in the floor of the tray up near the cabin. Pump sits in the tank held in by a circlip...
take all the screws out of the big panel on the floor of the tray and lever it up with a screwdriver ect it takes a bit as its held in by mastic (silicon that doesnt set) on top of the tank you will see the fuel lines and loom going into the tank . its held in by one circlip .. release the circlip and pull the pump assembly out . from memory the fuel lines come off fairly easily so you can take the whole pump assembly out . there are a few plastic clips around the edges .. release them and it will come apart .. be careful not to brake the plastic clips as they are fragile . if you need to replace the pump you will probable end up cuttint the lines on the pump and replacing then too as they are glued on . good luck
