Results 1 to 14 of 14
Thread: Excessive oil consumption
    redlion05's Avatar
    redlion05 is offline Red Lion 05
    VY Calais Series 2
    Dec 2005
    Exclamation Excessive oil consumption
    Hello everyone.
    Just wondering if this can be considered serious.
    My oil has dropped below the add line on the dipstick after 7,000 kms. Is that normal for an ecotec engine?
    Otherwise, can the engine have signs of wear and tear on the piston rings etc?
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    Oh also, (if it accounts for anything), i travel on freeways alot, could that contribute to oil loss thats this significant?
    2002 VX Calais
    Apr 2005
    Gold Coast
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Any leaks?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Didn't you say in another thread that you are using 10-30w if so that might be the reason.
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    Yes, I am using 10w -30 and used it in my vn calais and it used very little but unfortunantly, this engine seems to drink the oil. I'm considering on taking it back to the dealership but was curious if this is considered normal? There are no signs of leaks anywhere as i check them today. The smark plugs were normal as well. Any other ideas?
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    id use a 10w40 or 15w50 and see if it still does it with them
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    I'll speak with the dealership and see what they can do. Hopefully they can rectify the issue and i don't have to pay much...or anything at all. I hate car problem....especially after spending nearly 16k on this car. URGH!!!!
    Apart from leaks, is there any other way it could be burning the oil quickly? Is 10w - 30 to thin of an oil? In the booklet, it mentions that as the ideal oil and hence why i purchased it
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    10w-30 is too thin in my opinion, In my cars manual it says 20w-50 normal use and 15w-50 for snow use (I think) my engine is an ecotec as well. But 20w-50 is what I use and I have no problems barely any oil loss.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Check your Rocker cover gaskets , coomon VY problem , oil seeps past & runs down the rear of the engine , jack up car & check if your Gearbox pan is oily & drippy, chances are its from the rocker gaskets seeping oil. Buy a new pair of rocker covers with gaskets for about $120.....
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    1. You do not say how many kms the car has traveled but that level of oil consumption is excessive obviously.
    You should be changing the oil every 5-6000 kms in any event and letting the oil drop below the add level is just neglect .
    2. If there are no external oil leaks of significance then it will likely be worn piston rings. If you had someone carry out an engine cylinder compression check before buying the car you would know the likely condition of the piston rings before handing over your cash.
    3. The problem is the oil change intervals in the book are for ideal/optimum running which very few owners ever do. So allowing the standard type mineral oils to run 10000 kms or so in the engine before changing will result in much more wear on piston rings, bearings and other moving parts. Furthermore many owners are too lazy or ignorant, or both, to check their engine oil levels between services and some will just skip a service to save money. They will allow the oil to run down to the add level or lower in an engine which is consuming some oil - and all engines will consume a bit. They do not bother to check radiator coolant levels either. This is the risk you run buying a used car.
    4. Apart from checking for external leaks I would get a compression test done on each cylinder. If you have a significant external leak you will most likely have oil dripping on the garage floor.
    5. Finally check that you do not have oil escaping into your cooling system via a failed head gasket. Look at the coolant condition in the radiator when it is cold.
    Relying on a used car warranty is no substitute for getting a thorough pre -purchase inspection carried out before buying a used car because countless wear and tear items are not covered by these used car warranties.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by brad_m_is View Post
    an engine shouldnt use any oil between services
    Oh? I don't think so, any engine will use some oil between services, the higher the k's, the more oil it will use. To the op, how many k's are on it? And even for a high k engine, I would be worried about using THAT much oil. Unless of course your oil changes are only being done every 15,000 k's AND your k's are over about 200-250,000.
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    Sorry guys. I have 149,000 kms atm and I purchased the vehicle with 142,000 kms. The oil the dealership placed put in the engine was castrol magnetec 10w - 30.
    Today I removed the existing oil and oil filter with a new oil and filter. The oil is Castrol Modern Engine 10w - 30. It running good atm and is at the full mark. I also replaced the spark plugs and fuel filter too. I'd consider doing a compression test but just wondering, do i remove all the spark plugs before placing the compression tester in the spark plug hole? Also, how much could i expect to pay for a compression tester for my vy?
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    oh btw, i didn't find any leaks evident around the rocker cover or next to the transmission sump and there is no oil to be found in the radiator cap.
  1. Excessive fuel consumption
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-03-2007, 05:59 PM
  2. Excessive fuel use
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 10:00 PM
  3. Excessive oil use?
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2005, 01:50 AM
  4. excessive fuel consumption (92 vp)
    By tung in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 11:01 PM
  5. Excessive Fuel Consumption
    By bushy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2003, 08:51 PM
