Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: 22's On VY R8
    VYII R8
    Jul 2010
    QLD
    Default 22's On VY R8
    Hey I was wondering if anyone is running 22's on there VY? I just Bought a Clubby on 20's and am wanting to go a little larger in size. Any thoughts, recommendations or advice on this matter??
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I can't help you with your answer, but 22" will reduce handling, braking and traction. There just isn't enough sidewall to allow the tyres to properly function. Also I'm not sure it would be legal, and I'm 99% sure the load ratings won't match. Basically no insurance if you have an accident.
    Ronald Reagan (1986)
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    You'd have to run tyres like licorice straps with about 50mm between the rim and the road, and even then it would probably be greater in diameter than the original wheels, so your speedo would be way out, your clearance to the suspension and guards would be non-existent. And as acarmody says, the car would ride and handle like shit and be illegal anyway. Definitely not a good idea.
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i wouldn't do it,
    imagine the "hsv" camber wear on 22 inch tyres you would want to own a tyre shop!
    My VL Walkinshaw replica project
    VX Berlina
    Apr 2007
    Also forgot to mention, you back and neck will hate you if you go 22s.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    VY executive
    Oct 2008
    I'm sure a bloke did it on street commodores forum, not saying it looked good but they can fit with some work.
    20s are a perfect size for vy's imo, maybe go something with a deeper dish if the current wheels arn't satisfying enough?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    No way to do it legally or comfortably, or without looking like a tool, wont be able to get it very low. Bad idea all round
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VZ SS
    Aug 2009
    Maitland NSW
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by VjamesY View Post
    Can you fit 245s with 20s? No. Therefore they aren't perfect.
    18s with 245s are perfect imo.
    VYII R8
    Jul 2010
    QLD
    Ok maybe Iam just a little excited about huge wheels and big brakes but for now I guess I will stick with a deeper dish 8.5" x 20" Rim. I know Diablo Wheels run a mad chrome plated range of wheels... Anyone else know any other brands of nicely dished 20's?
    p.s. Iam running 245/30/20's on my stock spring height R8?? You say they scrub? Although the 245's are only on the back. I can see where you would run into trouble up under the front strut tower...
    Dec 2008
    With little work i've seen a few people run a 9.5"x20" with a 265/30 tyre, try that. have a nice 5inches of dish.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by sweefu View Post
    'little work' = flared guards?
    Lets not forget that 225/35 barely clears the guard with FE2. I can't imagine how 265s fit with a 'little work' either that or they have 4wd suspension or they can only drive on perfectly flat roads or they have unusable amounts of camber :P
    Just because it can be done doesn't make it a good idea.
    WM Caprice,HQmonaro,,KTM530
    Jun 2010
    South Australia
    saw a ve ute with 22's on the other day looked killer. dont know if youd get them under a vy but imo they'd look fantastic.
  15. #15
    ParkwayDrv's Avatar
    ParkwayDrv is offline ɹoʇɐɹǝpoɯ ǝsınɹɔ ɐʍ
    VZ SSZ
    Feb 2009
    vy ss on 22's, i beileve they are 245/30/22 92w
    Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
    185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
  16. #16
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
  17. #17
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
  18. #18
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by rhinos View Post
    As other people have indicated here, you cannot run a 22 inch wheel and tyre combination that is legal and will fit the car.
    In QLD as in most other States you must retain the minimum load rating as for the standard tyres fitted by the manufacturer and, secondly, you must retain speedo accuracy in which ever tyre/wheel combination is fitted. In other words the unloaded diameter of the tyre will have to be the same size as the original equipment tyres fitted by HSV to the VY - not the 20s you have now which are not original.
    You cannot go with a very wide and very low profile 22 inch tyre that will meet both of these requirements because the tyre that meets the requirements will need to be much too wide to fit the vehicle.
    You may well be able to buy a 245 30 22 tyre that meets the minimum load requirements but that that profile tyre in 22 inch will be too large in diameter to retain speedo accuracy because the diameter of the tyre is much too large compared with the original equipment tyres fitted to the car. The car - the VY - pictured in the post above, if running those tyres, will more than likely have an illegal tyre /wheel combination.
    Finally, if you have comprehensive insurance on your car you have to disclose wheel changes to the insurance company as it is a vehicle modification. If you do not the company does not have to pay any claim you make regardless of what it is. I very much doubt that most - if any - insurance companies will accept a 22 inch wheel modification on a VY commodore.
  19. #19
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by TMM View Post
    LOL, looks stupid.
    I concur. They look WAY too big.
  20. #20
    Trayner's Avatar
    Aug 2008
  21. #21
    N/A
    Nov 2009
    Can 22's be run on a pre-VE? - YES
    Can it be done legally? - NO (Load rating + rolling diameter)
    22's aren't even legal on a VE...let alone a pre-VE.
    as for running 245/30R20's, what a lot of people seem to forget is that a 225/35R20 is a bigger tyre in diameter and in most cases is too large to be legal (not all). The bead area of the tyre still has to seat on the rim and with such little sidewall, the difference in diameter means that a 245/30R20 actually allows more clearance than a 225/35R20 in most cases.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
  22. #22
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
  23. #23
    VY executive
    Oct 2008
    Sorry I didn't clarify, but I'm saying 20's are a perfect size as for looks, not fitment. 22's would just look ridiculous and out of Proportion.
  24. #24
    VY executive
    Oct 2008
  25. #25
    VZ SS
    Aug 2009
    Maitland NSW
    Makes those brakes look tiny on that black vy.
  1. smik ve ute 22's DA LOOK...
    By dakman in forum VE - WM
    Last Post: 22-06-2011, 11:19 PM
  2. VE owners with 22's
    By ashtray1 in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-05-2011, 08:57 PM
  3. 22's on a vz
    By one in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-05-2009, 08:31 PM
  4. VK 304 22's
    By Holmez in forum VB - VC - VH - VK
    Last Post: 02-02-2008, 10:06 PM
  5. 22's on WH any probs?
    By walesy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2007, 11:47 PM
