Results 1 to 4 of 4
Thread: help needed with srs air bag fault after cluster change
    vy ss ute
    Nov 2009
    Default help needed with srs air bag fault after cluster change
    I went to put a new instrument cluster in my ss today and it came up with an srs air bag fault when I turned the ignition on. So i put my old cluster back in but the fault comes up on my old one as well now. Does the air bag system just need reseting somehow? I disconnected the battery each time i swaped the clusters has anyone run into this problem before?
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The issue is the new cluster will not be set to your cars options - often climate and number of air bags. This needs to be done in the car with the new cluster fitted. Holdens can do this with a tech 2 or a mechaning with the gizzmo. (phreddy on this forum may be able to help you).
    As for the air bag fault - once logged it must be cleared before it will stop. If you plan to get the new cluster fitted save getting it reset until it's fitted.
    and 3 Dangerous non ABS VN's
    vy ss ute
    Nov 2009
    thanks guys much appreciated tech 2 did the job.
  1. vt cluster change(help)
    By qik42c in forum ASR Audio & Electronics
    Last Post: 21-09-2010, 05:11 PM
  2. change ecu.. change memcal..?? fault finding
    By bandit10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-02-2010, 08:29 PM
  3. cluster instrument fault
    By chris1975 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2009, 08:19 AM
  4. VR Fault Codes 31 & 45 -Help needed
    By myvrwagonneedshelp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2008, 11:04 AM
  5. Cam change. HELP NEEDED.
    By 253@7k in forum General
    Last Post: 05-09-2006, 01:13 AM
