Results 1 to 12 of 12
Thread: VY Calais foglights -> Driving Lights?
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Default VY Calais foglights -> Driving Lights?
    Is there an easy upgrade available for the VYII Calais Foglights?
    Foglights are of no use to me (Sunny Queensland) but some decent driving lights might be usefull.
    I have no problem with wiring it up to come on only at high beam, but can I get something that will make it worthwhile without major mods?
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I'd say that you'd have to try and find some that are exactly the same size as the foglights. Shops like Supercheap etc, have a range of different sizes. Also you'd have to suss out how the foggies are mounted and try to get something that is the same/similar mount, maybe having to make up a bracket? If it was me, I'd try pulling one of the foggies out and "go shopping" to see what's around. Good luck, hopefully someone else has done this and will reply with more detail.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    couldnt you just get a HID kit for the fog lights and rewired it to the high beams under the dash? ive seen a few on ebay
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    There are some Narva ones I believe that are a direct swap. Can't remember the part numbers but Keep_Left who is a member on these forums is in the know. He doesn't seem to post much though.!
    Jun 2005
    Brisbane Bayside
    Yeh - it'd have to be doable - just hoping someone has done the legwork already Most importantly, it'd be nice to know if the result is worthwhile.
    Oct 2006
    Bogan enclave
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    For driving lights to be really effective, they need to be raised above the height of the fog-lights, more towards the height of the head-lights. Foggies are designed to illuminate the road immediately in front of the car, below the fog, which is why they are mounted so low on the car. Just replacing them with some form of driving light will work but the lights won't be very effective because they are mounted too low to throw their beams well ahead of the car.
    Oct 2006
    Bogan enclave
    VE SV6 Sportswagon
    Jan 2010
    Mornington Peninsula
    VY SS
    Jun 2006
    Albany
    hid's would be good but the foglights are designed to spread the light differently than a driving light would, so you would need to find some lights that fit the hole and are designed like a spot light then put some 55w hid's in them which might work better if wired like normal spotlights.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by Calaber View Post
    Yes I agree. The current FL mounting position is much too low to be really effective for driving lights. From my experience in fitting driving lights to 2 different cars, they need to be mounted approximately the same height as the headlights.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    I can tell you from experience that the lower you mount the driving lights the less efficient they are. The higher you can mount them - the better they will perform. I suggest a set of Phillips Crystal Vision, or similar, high beam globes into your headlights. I understand they work quite well.
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. Vs Calais parker/driving lights dim?
    By GMHCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2009, 03:20 PM
  3. VX Calais foglights onto a Berlina Front bar.
    By King_berald in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2009, 04:45 PM
  4. Wanted,VX Calais Driving lights
    By hobbyhorse05 in forum Swap / Wanted to Buy / Trade
    Last Post: 27-06-2006, 08:34 PM
  5. Fitment of Calais Foglights to VTII Berlina
    By ScottB_33 in forum Electrical Wiring / Questions
    Last Post: 03-03-2006, 05:33 PM
