Results 1 to 8 of 8
Thread: LED Indicator Bulbs
    binghy is offline Matty 038
    Vy Equipe Series 2
    May 2009
    adelaide
    Default LED Indicator Bulbs
    I just installed LED indicator blbs and now they are flashing faster than normal.Do i need to change the flasher unit to fix this.If so does anyone know where i can buy 1.
    Thanks
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    yes you need an LED flasher relay, try ebay? other than that i think narva make them
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Correct me if im wrong but could it just be ones in the wrong way? Also a question for you. With the LED bulbs can you see the individual LED when you indicate or brake or whatever?
    Vy Equipe Series 2
    May 2009
    adelaide
    yes u can see the individual LED light up.
    They cant be in the wrong as the are an offset pin and only fit 1 way.Thanks for the tip on flasher unit will try autobarn and the likes tomorrow
    Thanks
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Quote Originally Posted by Skid Bro View Post
    This depends if the lens is frosted or see-through, and also the LED type. e.g if its multi-angled to fill the lens with light, or pointed directly out
    calais24/7's Avatar
    Jul 2009
    True, So what do you reckon they would be like in vl calais tailights or do you have no f***ing idea lol
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    For VL, I would be getting a multi-angled globe as it would fills out the whole lens, rather than a straight bulb where you would see a more of a circle of light where the globe is.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Flashing too fast is common as they would be different wattage to normal globes. My mate put an aftermarket front bar/indicators on his R33 and i fixed them flashing too fast with some 10kohm resistors they are only a few dollars from jaycar. The resistance you need will depend on what the globes were and what they are now.
    Cheers.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
  1. chrome tipped side indicator bulbs
    By BlackVT:D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2010, 11:09 PM
  2. green bulbs under driver side, passenger dash and centre console/rear bulbs
    By GMHCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2009, 01:12 PM
  3. Fog Light Bulbs
    By MickVE in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-08-2009, 09:05 AM
  4. new bulbs
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2008, 10:03 PM
  5. Dash bulbs for VT
    By dusted in forum General Discussion
    Last Post: 07-08-2005, 08:53 PM
