Results 1 to 4 of 4
Thread: Vy LPG issue
    VY Equipe LPG
    Aug 2010
    Smile Vy LPG issue
    Hi fellow Commodore lovers,
    I have a 2004 VY Equipe with factory/Dealer fitted LPG. While running on LPG it's fine apart from when I let off the accelorator and coast, the revs will drop below normal idle speed. It will sometime surge and jump up the revs again but will settle back and do the same again and sometimes it will stall and this can become quite unsafe as I try to start it again while rolling. If I slow and apply the brakes it seems to settle to normal idle speed ok and will idle happily while waiting for the lights to change. This only happens while on LPG, when I change to petrol it behaves perfectly. Is it a problem with the LPG system, a vacuum hose that's connected to the LPG system, or an o2 sensor issue, but my assumption on the o2 sensor would be that it would misbehave when on petrol as well.
    Cheers to anybody that has some advice.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    sounds like its leaning off on deccel and stalling the engine could be a number of things secondary diaphragm sticking or bleeding off pressure , have you checked the vacum hoses for leaks ? is the idle higher on petrol too ? any trouble codes or engine light coming on ? has the vehicle back fired recently ?
    VY Equipe LPG
    Aug 2010
    Quote Originally Posted by strgas View Post
    Cheers strgas,
    On petrol idle looks to be the same, around 650 rpm, I've checked the hoses for vacuum leaks but can't detect anything, all attached well and no splits or cracks. No engine codes show, only the Battery light when it's about to stall or stall altogether and no backfires recently.
    It started doing this some time ago, but I adjusted the idle at the cable bracket, probably six months ago. This seemed to solve the issue well but when the condition started again I adjusted it more but then the car wouldn't start. I'm guessing this is because of the throttle position sensor.
    The thing I'm wondering I guess is if there is a simple solution or it's time to take the car in for a gas tune, but the thing is it's running beautifully apart from this issue, doesn't miss a beat otherwise.
    Thanks again.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    yeah it will be a combination of TPS and closed throttle position.
    Get it retuned.
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
  1. VR ECU or BCM issue
    By wkwi3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2010, 08:17 PM
  2. 07 SV6 Air Con issue
    By zomble in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-01-2010, 05:21 PM
  3. vs 12v issue
    By vh sle !!!!! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2009, 11:06 PM
  4. bcm issue
    By buster1192 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2009, 08:23 PM
  5. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
