Results 1 to 4 of 4
Thread: squeeking from drivers side front
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    Default squeeking from drivers side front
    hi all, i have a vy ss and since i got it on tuesday when driving along from low speeds to high there is a very annoying fairly lound squeeking type noise from pretty sure drivers front wheel area, anyone have an idea, cheers
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by 94calais View Post
    hi all, i have a VY ss and since i got it on Tuesday when driving along from low speeds to high there is a very annoying fairly loud squeaking type noise from pretty sure drivers front wheel area, anyone have an idea, cheers
    I suggest you jack the car up and spin the DS front wheel and see if you can replicate the noise (as you said it occurs at low speed). If so it's probably in the brake mechanism. It's unlikely to be a wheel bearing issue.
    If there is no noise on spinning the wheel then it is likely to be a worn suspension component - possibly a worn or disintegrated rubber bush but it could be a number of items. You might be able to replicate the noise by gently bouncing the car up and down on the DS front while the car is at a standstill.
    In any event you need to have it professionally checked out.
    If a thorough pre-purchase mechanical inspection had been done on the car by a competent inspector the problem would have been identified before you bought it on TUES.
    No doubt there will be others here who will comment on the problem now.
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    all good guys i thought it would be the pads so i got all 4 changed the front still done it then changed the back 1's and woohoo no more noise as i suspected, thanks anyway guys
  1. Drivers Door Squeeking
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2009, 06:22 PM
  2. VP drivers side front indicator
    By arrow224 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2008, 08:48 PM
  3. WTB [SA ONLY]: VY/VZ Drivers Side Front Door
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 23-09-2008, 03:13 PM
  4. WTB SA: VR Front drivers side guard
    By V-ahhh in forum Swap / Wanted to Buy / Trade
    Last Post: 12-05-2008, 12:55 PM
  5. WTB:VT Front drivers side guard
    By Noy in forum Swap / Wanted to Buy / Trade
    Last Post: 01-10-2007, 09:40 PM
