Hi there
I've managed to track down a level 3 cluster for my vy. Its out of a VY CV8 monaro.
Part no 9211895
What am wanting to know is fill this plug into my VY series 2 S Pack ?? THe current owner of it has it in his series 1 vy v wagon. I want to get the odometer recalibrated as its nowhere near my current km's and also have heard through the grape vine may need a fuel guage recalibration.
Help will be appreciated
Many thanks
you cant and wont beable to change the km's on the cluster (if your trying to wind them back that is)
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
The cluster will nedd to be set you your cars spec. Like the climate system and number of air bags.
I've sent 3 clusters to phreddy on this forum for re programming. CVontact him and see how you go. If you run the cluster and it is not set right the error codes will be triggered and will need a visit to Mr Holdens or the like with a Tech2 gizzmo.
and 3 Dangerous non ABS VN's
You sure? Cause holden matched the kays on mine when i got a clubsport cluster installed. Admittedly it was brand new in box. I've been told they can change the kays on it so long as it reads under 100k
As for the cluster. No. you cant mix s1 and s2 clusters. apparently the fuel sender is backwards between them. and its a different plug.
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? - George Carlin
If the cluster has done over 100kms the ODO can't be changed with a Tech2 so Holden will only be able to program the right number of cylinders, transmission, airbags, diff ratio.
However with the right equiptment it is possible to change the ODO on a used cluster, Phreddy from ASR-Audio can do it.
yep go and see preddy he can help with the kms, he did mine.
However leave your old cluster in untill you go and see him as he can only copy the kms from what you have and put in into what you have got.
