Results 1 to 7 of 7
Thread: clutch problems and vibration.
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    Default clutch problems and vibration.
    ok bassically i was driving down the freeway went to overtake some1 and the clutch slipped so i backed off kept going and there was the smell.. no biggie. but as i get off and drive through normal streets there is now a god aweful vibration through the clutch pedal. it gets worse as the car revs then kinds smooths out after 3.5k revs.. weather its in gear or not and weather the clutch is engaged or not.
    please if you know what this possibly could be can you explain it to me.
    i have driven plenty of cars with f'ed clutches no dramas but the vibration has me worried.
    and yeah i checked the engine mounts (not the gearbox ones though)
    Aug 2010
    central coast
    bumping it up.....
    id this the wrong forum for this thread or something? or just does nobody know
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Well considering the clutch is stuff and possibly the pressure plate, thrust bearing ect as well, one would think a removal of the gear box will be the next step and then you'll be able to turn over the engine without the box in play to rule out that vibration.
    Cheers,
    Dave
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Probably glazed the flywheel when u cooked it.
    Do a few hard launches in 2nd gear with a bit of slip to try and clean it up.
    Silver Certified.
    Aug 2010
    central coast
    when i take it out this weekend ill try to diagnose it a little better and try ur trick RiCey
    then if its still stuffed ill have to follow caaf's orders haha
    Nothing, at the moment
    Sep 2010
    Aug 2010
    central coast
    incase any of you were wondering it is fixed now.. after letting it cool down (for a week) i took it for a bit of a hard drive.. and it fixed itself (it probly didnt fix itself but its hiding for now)
    so thanks guys.
  1. clutch pedal vibration
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2010, 10:21 AM
  2. Clutch problems
    By 05LVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-05-2010, 03:11 PM
  3. VX clutch problems. PLEASE HELP!!
    By harvz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2009, 08:56 PM
  4. Vibration problems, help
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2007, 05:27 AM
  5. clutch problems !!!!
    By stevenwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2006, 05:30 PM
