Results 1 to 13 of 13
Thread: Remote Wire for Subwoofer?
    2004 VY Auto Calais
    Aug 2010
    Default Remote Wire for Subwoofer?
    Which wire do i tap behind my headunit for the remote wire for my aftermarket amp?
    I tried tapping the yellow cable and it did not work.
    Right now im using the 12v behind the cigarette lighter but i want to remove that and use the propper accessory wire.
    Thanks.
    Car is a 2004 Calais with Blaupunkt Stereo.
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    How are you connecting the amp to the headunit?
    Phreddied HU?
    Hi to low converter?
    Check out my ride!
    2004 VY Auto Calais
    Aug 2010
    Low converter tapped into the back right parcel shelf speaker in the boot
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    On aftermarket stereos the hemote wire is usually blue I believe? But don't use the aerial wire (often also blue but with white stripe) or you'll get no amp when on CD.
    Factory units don't usually have a remote wire - so the yellow accessories wire would usually be the correct wire - but you say that didn't work?
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    2004 VY Auto Calais
    Aug 2010
    Quote Originally Posted by Fletch_QLD View Post
    Yes well i tried tapping into the wire down the side, however i wasn't sure it was the correct loom.
    Whats the best way to get to the yellow wire, i removed the head unit however behind it there was only some plugs and no wires.
    If i tap into this Accessory cable will the amp turn off when i turn off the headunit?
    Thanks.
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    That plug is the wiring loom - the ACC yellow wire will be attached to the back of it. There are 2 clips on that plug, push in those clips and the plug will fall out to the back.
    Then remove the side dash panel (passenger side) and you should see the wiring loom - splice your wire and tap in there.
    Check out my ride!
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    take off the steering wheel shroud get urself a test light (or somebody that knows colours) and hook a wire to the accessories wire on the back of the ignition barrel and run ur own wire.
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by willy_manilly View Post
    You need to remove the steel shell that the factory head unit slides in to - behind that is where you can get at the loom.
    Tapping in to this cable will not result in the amp turning off when you turn off the stereo - it will have the amp turning on/off whenever you turn the key on/off. Factory head units have no remote wire for aftermarket amps. Therefore, if tapping in to the stereo loom is difficult, just tap in to any accesory cable - tapping in to the cigarette lighter for example (as you have done) will achieve the same result as tapping in to the yellow wire on the stereo loom.
    2004 VY Auto Calais
    Aug 2010
    Ok cheers, i have tapped into the Lighter 12v
    However im getting a constant HUMM when the headunit is off and the amp is left on.
    Im not sure whats causing this issue but its rather annoying
    Jun 2005
    Brisbane Bayside
    You could put a switch on the remote wire. Try a more solid earth on the amp?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    You will have to open up the headunit to get a remote that turns on/off with it. Afaik the headunit always has power and the BCM tells it to turn on/off.
    Here's where Preddy's mod gets power from (red wire - will turn on/off with headunit):
    It would be wise to use this to run a relay, or add a current limiting device in series with it (e.g. 100mA light bulb) to prevent a short damaging the unit.
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    Ive got my remote wire connected to the spare fuse of the accessorys... and the amp turns on and off with the headunit.
    vz acclaim
    Jun 2006
    Im pretty sure the vy is the same as vz. Passengers side of ur centre console u'll find a mobile phone hands free jack that runs through ur head unit tap into the yellow/whiteline wire easy as
    TEAM CLOWN RACING
  1. Subwoofer wire
    By Dan_VX_Spac in forum Car Audio
    Last Post: 11-02-2010, 07:04 AM
  2. Remote switch for subwoofer
    By Fletch_QLD in forum Car Audio
    Last Post: 11-04-2009, 04:27 AM
  3. subwoofer wire question
    By benny mckellar in forum Car Audio
    Last Post: 24-09-2008, 07:43 AM
  4. speaker wire for subwoofer
    By roon_VR in forum Car Audio
    Last Post: 01-04-2008, 01:07 AM
  5. Subwoofer/Amplifier wire colour
    By Commo Fan in forum Car Audio
    Last Post: 04-12-2007, 10:32 PM
