Results 1 to 4 of 4
Thread: what to look for when buying a vy ss??
    vy s pack
    Mar 2010
    Default what to look for when buying a vy ss??
    so in the next coming weeks i will be looking at purchasing a vy ss. what are some frequent problems that i should look out for??
    thanks
    vy ss sandman 5.7
    Feb 2009
    Up North Wa
    it not being a vy ss? joking um not being a manual and a v8 is all i can think about. ohh and bodywork
    Vy ss sandman, bringing back the past!
    [CENTER]
    Nothing, at the moment
    Sep 2010
    Quote Originally Posted by marrrk View Post
    thanks
    If its manual, start it and listen for gearbox knocking/rattling. Turn steeering wheel left to right and back for knocking and shuddering. Check clutch fluid colour. Test drive, check brakes firmly for shuddering, do a full circle left and right, listen for diff clunking. Listen to engine at idle for ticking, tapping (will tap abit when its cold but should stop at normal operating temp) open oil cap, check for steam and blow-by. CHECK belt tensioner/idler assembly as ive done 4 of them!! If auto check shift pattens aand check coolant for trans oil (mate brought a vy sv8 with tranny fluid in coolent) thats all i can think of from experience,hope it helps great cars!!!
    251rwkw VY SS
    Mar 2010
    Check under the car for common power steering leaks and LSD leaks, CHECK BACK TYRES AND CHECK GUARDS FOR RUBBER, like the above comment check all of the fluid levels and colour, take out the dip stick and smell the oil.. make sure it smells nothing like petrol, ask them what oil he/she uses and how regularly it gets changed. Goodluck with the search mate! VY SS is the shizzz!
    "If you want more inches.. STROKE it.."
    "Wait are we still talking about cars!?"
  1. buying a vh
    By off_tap_vl in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-08-2009, 05:10 PM
  2. buying a VZ ute
    By maxpower QLD in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-08-2008, 06:23 PM
  3. buying a vt ss 5.0L??
    By rekless driver in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-02-2006, 03:38 PM
  4. buying a vt ss 5.0L??
    By rekless driver in forum General Discussion
    Last Post: 30-01-2006, 06:37 PM
  5. VN buying - what to look for?
    By mitch01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2005, 08:26 PM
