Results 1 to 10 of 10
Thread: 10psi Pulley (Plugs, coils, leads, thermostat)
    VY S Pac Series II Supercharged L67
    Mar 2010
    Wollongong
    Thumbs up 10psi Pulley (Plugs, coils, leads, thermostat)
    Im getting the 10psi pulley upgrade on the weekend.
    I currently have standard NGK spark plugs, Standard leads (replaced 100kms ago) and stock coils and factory thermostat.
    The car has 160 000kms on the odometer.
    Will i need to upgrade any of the parts mentioned above when I install the 10psi Pulley upgrade?
    Cheers guys
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    get the cooler plugs for sure , and thermo mayb. the l67 coils are fine, they put out the same or more power than the msd coils... one guy used to run 10 sec's of factory coils so think there fine. and standard l67 leads are the most reliable,
    will fine the part numbers for thermo and cooler plugs
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    Sep 2009
    goldcoast
    the cooler thermostat part no is- dayco dt22a. got mine from repco $20ish
    the plugs- ngk bpr7efs-15 ,, they come gapped at 1.5mm but need to be regapped to 1.3mm. some people go 1mm gap if have missfiring issues under full boost.. but the bigger the gap the better so try 1.3mm first..
    Mar 2010
    Wollongong
    Sep 2009
    goldcoast
    just get em from supercheap. $4.50 each , there the same. gapping thems easy.
    VX S S/C & BA XR6T
    Feb 2009
    If a missfire is felt then yes change some parts.Just make sure you run 98 octane and delete your boost solenoid.L67torque has it all on there.Stay clear of that linked site above also,they(him)operates as FIT Technologies also.Mace,Y/Terra,BYE Perf,TTT Perf and Intense Racing in US will take care of all your needs at better prices.
    If you get a slight missfire then just try regapping your std plugs if serviceable.What charge said above get them from a Autostore.I think the V8 ones are pregapped to 1.3 by memory just go heat range 7 as above said also.Std leads and coils are killa and more than up to task at hand.
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by Vy S SC View Post
    Thanks mate, your a legend.
    would you think these plugs will do the job
    Colder Plugs for Supercharged V6 Gapped to 1.0mm
    I think stock plugs will be fine but if you want to go 1 heat range cooler go n ask for NGK BPR7EFS-15. They will need to be re gapped to 1.3mm, no less.
    VYII Calais L67
    Mar 2010
    Wollongong
    Sep 2009
    goldcoast
    yeah i think it is. think 1.3 mm is pushing it ..
    Dec 2006
    so is the 1.5mm stock gap of the plugs too much?
    Yes the 1.5mm gap is a tad too much. 1.3mm will be fine
    VYII Calais L67
  1. Standard belt with 5% overdriven balancer and 10psi pulley?
    By TobyDSim in forum V6 Development And Modification
    Last Post: 23-06-2010, 11:45 PM
  2. Re-tune for 10psi pulley?
    By wbartholomeusz89 in forum Yella Terra
    Last Post: 09-02-2010, 09:49 AM
  3. Installed 10psi pulley and car is now playing up!
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2009, 07:06 PM
  4. what size is the 10psi pulley for the m90 eaton
    By robbie77 in forum V6 Development And Modification
    Last Post: 13-11-2005, 10:52 AM
Tags for this Thread
