Results 1 to 17 of 17
Thread: vy gen3 tapping noise
    vy berlina international wagon
    Aug 2010
    whyalla
    Default vy gen3 tapping noise
    my vy berlina international has developed a tapping noise, seems to happen sometimes on startup or if your idling for a bit like in a drive thru or something, than when you drive off it seems to go away, its on the left hand side sounds like the rockers tapping on one cylinder and when it starts doing it the engine develops a miss. any ideas would be great
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    when ya was last oil and oil filter change? and what vicosity oil are ya using?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Aug 2010
    whyalla
    700kms ago and before that it was 3000kms but than it started making the noise, castrol 10w/40
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by vyberlinainto View Post
    ahh kk so fairly new, how many kms has it done? (the car that is)
    Aug 2010
    whyalla
    the car hasnt been thrashed or been doing burnouts since weve had it either and its done about 155000kms
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok another vy v8 owner mite be able to help more, you could try using that Nulon Lifter Free oil additive, it worked on my vs, if that fails maybe thicker oil? thats is if it is the lifters
    Aug 2010
    whyalla
    if you go on the highway for a bit of drive when you pull up and get out thecar is dead quiete
    Aug 2010
    whyalla
    we tried 30w/70 for an hour but didnt make a difference, every time ive taken in it to the holden dealer ship it wont make the noise
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Well cant be the lifters by the sound of it then, hopefully another member can help ya more
    251rwkw VY SS
    Mar 2010
    Had the same tapping noise in my car.. i used to use the Castrol Edge 5w 30 fully synthetic and change my oil every 5000kms but changed oil to the Nulon 10w 40 Full Synthetic and the noise went away.. In your case if its an early model VY it could suffer from piston slap as it was common in the VT,VX and early VY Gen3's.
    "If you want more inches.. STROKE it.."
    "Wait are we still talking about cars!?"
    VY II SS Ute
    Dec 2008
    Mine has the same thing. Right hand side of engine constant tapping, gets louder and faster as revs go up. I have an early 04 model. It is still under used car warranty and have taken it back to the Holden dealer, they fixed it and it came back. I also have a power lag when it is cold, feels like it is missing, then you get over 3k and it boots off.
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    dont worry, i have the same noise as well. im not sure how to get rid of it.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VZ HSVDT
    Aug 2007
    melbourne s.e suburbs
    sv8
    Sep 2010
    mid north coast
    Mate mine is doing the same dont bother with the lifters you have to pull the head off pretty expensive job......probably going to have a look at oil pump pick up........ps i have tried all different oil grades and have done lifters but hasnt fixed anything
  15. #15
    VY calais 5.7
    Sep 2010
    Doreen
    I did lifters on mine and while i did that put a new cam in as well and still has the same ticking noise im thinking maybe the oil galleries might be blocked or the oil pick up is no good so my next step is to get the oil pressure checked and see if it's starving for oil when the ticking happens.
  16. #16
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by VZHSV View Post
    Do not use Oil Adatives in LS motors highly not recomended
    whys that?
  17. #17
    VY II V6
    Dec 2006
    It's not one or both of the exhaust manifold gaskets??
  1. tapping noise
    By mardysholden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-01-2010, 10:52 AM
  2. tapping noise in engine
    By cbb01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2006, 06:57 PM
  3. tapping noise inengine
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2006, 12:08 PM
  4. Tapping Noise
    By Bloka in forum General
    Last Post: 24-07-2006, 01:31 PM
  5. Loud Tapping Noise
    By nelly77au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 01:44 PM
