Results 1 to 5 of 5
Thread: Drive belt
    VY SS
    May 2009
    Default Drive belt
    I need to replace a pulley off the ss..its off the small drive belt thats connected to the A/C but i have no clue how to remove the belt.
    Anyone know?
    Cheers.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Locate the tensioner pulley. Use a ring spanner or tube spanner on the tensioner pulley bolt (15 mm from memory) and press down gently away from the belt.
    ................... As shown here for the V6 cars...engine belt farrkd!!!
    Moving the tensioner pulley frees the serpentine belt and it can then be removed. Ensure you draw a diagram of the belt around the pulleys before removing the belt so you do not get confused trying to refit it.
    VY SS
    May 2009
    Nah not the main belt..there's another little belt the runs from the harmonic balancer to the A/C unit. The ss has 2 belts. Thanks anyway.
    Hot House VY SS
    Jan 2010
    You will have to remove the main drive belt to get the AC belt off as it sits behind it. The main tensioner pulley on an LS1 is the top left when you open the bonnet. The AC tensioner is lower down and looks the same
    VY SS
    May 2009
    Ahh right, thought so..
    thanks for your help, cheers.
  1. DRIVE BELT URGENT .where can iget a drive belt in brisbane sunday for vt lsi motor
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2010, 03:24 PM
  2. drive belt
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2009, 09:40 PM
  3. Drive Belt.
    By Tam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 07:49 PM
  4. Drive belt ?
    By BLACK-2002 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2007, 09:38 AM
  5. Drive belt gone?
    By gyp23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2006, 11:05 AM
