Results 1 to 11 of 11
Thread: Cruise control "clicking."
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Default Cruise control "clicking."
    Hey fellas, ever since I got the VY, I noticed that when I disengage cruise, there's a distinct click sound coming from under the bonnet. Had the car four years now and it doesn't bother me, and I've had no issues with it. However, yesterday I noticed it makes a similar noise when I activate cruise as well, questions are: Is this normal? Is there a way to lubricate or adjust something to rectify the sound? Cheers.
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Coming fault and issue.. You'll need to raise the unit up from the body as the unit would just be touching.. There is a Techline on that I could dig it out if you wish (PM)
    Cheers,
    Dave
    May 2009
    Melb, Vic
    Right oh I found the techline on it. hopefully you have success
    Attached Files Attached Files
    Cheers,
    Dave
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Thanks mate, who'd have thought such a simple fix! I'll do this today, ta.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Well, I tried the above suggestion and no cigar. So I pulled it off again and even put rubber spacers beneath the front two bolts too, but is still just as noisy as before. I really thought this would have been the fix as it made a lot of sense, but maybe the sound is coming from within the unit itself. Any other suggestions anyone?
    Ignited-SV6's Avatar
    Ignited-SV6 is offline Sleek and Class
    VY Berlina
    Jun 2010
    I noticed that as well and I found a way to avoid it.
    I'm not sure if this is obvious or this is how its meant to be done but...The clicking or *Clocking* noise that you hear when you engage the Cruise Control is only when my foot is OFF the accelerator.
    This means that if you engage the Cruise whilst your foot is maintaining 80kmph (for instance) there is no click, clock, clack or wtvr. Simply engage the CC whilst your already maintaining that speed.
    Same this goes for when you want to disengage: Cruising at 80kmph, lightly hold the accelerator so that your foot is in control of the speed, then simply disengage whilst your foot is resting on the pedal.
    This may only mask the noise of the click or completely avoid it, I'm not too sure yet. Give it a shot and let me know how you go.
    Cheers and happy cruising.
    My Ride
    http://forums.justcommodores.com.au/...a-ss-rims.html
    Next mods: Lowering, 4 Channel Amp and eventually 19's
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by Ignited-SV6 View Post
    I think you may be right on that one. I'm lazy and just use the cruise instead of the accelerator most of the time if you know what I mean. I'll give it a go though, might be the slack being taken up and released in the cable, eh? Cheers.
    2004 Calais VYII Gen3 5.7L V8 + Impco Sequent LPG
    Mar 2005
    Western Sydney NSW
    I noticed the same mlid "clunk" on my VYII Calais' cruise control when engagin or disengaging, from when I first got the car.
    Whilst getting a regular service (years ago) with Holden, asked them to investigate. They said there's nothing wrong.
    I still occassionally notice it (only if the road noise & radio noise is down) and it's not got better or worse in 5 years.
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    haha mine does it too .. but i just thought it was normal, i just thought it would be slack in the cable, but if theres a fix for it that would be pretty sweet
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by a1k3m1 View Post
    Well I've placed rubber washers under the three bolts on the cruise module but no cigar. Ah I guess it's good to know that others do it, too. Mines done it for the four and a half years I've had the car. Just wasn't sure if it was the only "clicker."
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    It's backlash from the slack in the cable. Depressing the accelerator will remove some slack in the cable, therefore the click is quieter, or doesn't occur at all.
  1. Do "police pack" cars have a standard v6 or the "high output" one?
    By Gibson_83 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-08-2011, 05:42 AM
  2. VZ Sv6 " No Traction Control Button"
    By Rhodzy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2009, 07:17 AM
  3. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  4. Calais turbo's "Yellow BT1 cruise" pics
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2006, 09:54 PM
  5. "Aussie" Traction Control
    By ozute in forum The Pub
    Last Post: 27-07-2005, 01:54 AM
