Hi GUYS I have a 2002 clubsport i,ve owned it for about 5yrs. It,s developed a massive oversteer problem when going around left hand corners , I,ve had the wheel alignment checked , we had it up on a hoist at garage and checked all suspension and steering and can,t find any thing wrong ,all the suspension bushes are nolathene.the mechanic thought it might be a LSD Diff problem . Its really scary to drive makes your heart skip a beat . CAN ANYONE HELP ? CHEERS.
P.S it only does it when going left.
Ease up on the right foot action could help a little...
Seriously, If the suspension & tyres are all OK then it's LSD.
Good luck with it.![]()
It sounds like a suspension issue which has simply not been identified . (I'd also thoroughly re-check the rear alignment).
If the standard suspension has been fiddled with or modified in any away it is all the more likely an area to investigate more thoroughly with a competent suspension specialist.
As for the theory that there is a diff problem I would be curious to hear an explanation as to what the diff would be doing to cause a severe oversteer condition on left turns, what the malfunctioning or damaged parts in the diff were that caused such action , why this would only occur when the vehicle turns left, why the diff sounds like it is operating normally rather than noisily grinding or chattering itself towards failure....etc. etc...?
is your front sway bar broken or lose?
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
+2 for the sway bar
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
