Results 1 to 12 of 12
Thread: Oil pressure sender
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Default Oil pressure sender
    Does the oil pressure sender unit near the oil filter simply switch on a dash light if oil pressure drops? I wonder is there a way to not only have this but also an electrical pressure guage?
    Dec 2009
    Looking at the wiring diagram in the manual I have the oil pressure sender goews into the power train control module. I am not sure if it is a simple switch or if it is a transducer.
    VY SII HBD Calais L67
    Dec 2006
    It is pressure switch. Pressure goes below a certain pressure level and the engine goes into limp home mode. Won't save the engine 90% of the time though
    VYII Calais L67
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by VYMAD View Post
    People usually fit a T section in Brass or Stainless Steel in the correct thread size where the existing sender unit screws in. This gives you the 2nd outlet for the sender unit on the pressure gauge.
    There are some posts on this in this VY forum you can find with the search function.
    (One problem here is that there is virtually no slack in the wiring to the existing sender unit -such as is the case in my car - and this could make fitting the current sender unit to the new T section difficult without modifying (lengthening) the wiring. So I would check that on your car first.)
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by Sean880 View Post
    Aaaaah k, sounds like a pain in the ass. I'll wait until I'm REALLY bored before I attempt this one!
    Dec 2006
    You need a VDO T piece. 032- 023 or something like that. I extended the ops wire when I installed my autometer guage sender. Stock switch screws into the sode of the t piece and the am sender goes on the end
    VYII Calais L67
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Ok thanks, then just run the oil pressure guage wire through the firewall to the new oil pressure guage, eh?
    251rwkw VY SS
    Mar 2010
    sorry to hijack your thread mate.. but do you know if you can put VZ Oil Pressure and Volts gauges onto a VY? (the ones that sit ontop your centre cluster) ?? they are electrical.. is there any wires in there that they can connect to or does a new line have to be run?
    "If you want more inches.. STROKE it.."
    "Wait are we still talking about cars!?"
    Dec 2006
    Yep, the autometer sender earths through the oil filter adapter housing so only 1 wire (sender) gojng back to the gauge. The other 2 are for lighting. Other brand senders have 2 wires from the sender so one is earth and the other is the sender signal.
    The t piece you need is a VDO part number 230.032. Be sure to use teflon thread tape on all fittings and don't delete the factory op switch whatever you do
    VYII Calais L67
    Dec 2006
    Quote Originally Posted by faBReGaS View Post
    The bezel won't fit. You can buy a loom from NVU, Holmart or JP but custom is a piece of cake............as long as you have the OEM senders. Better off going for an aftermarket gauge IMO
    VYII Calais L67
    251rwkw VY SS
    Mar 2010
    there's a set of gauges on eBay at the moment. would you be able to tell me if they fit please?
    Here is the link: vy ss gauges, Cars, Bikes, Boats, Instrument Clusters, Gauge Holders items at low prices on eBay.com.au
    its the red ones.. i really want a set for the SS.
    Thanks heaps mate!
    VS commodore
    Mar 2012
    gosnells
    has anyone every had to replace the housing the sender and filter is connected to on the vs '
  1. oil pressure sender
    By david dubbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2010, 05:21 PM
  2. Oil pressure sender
    By 85DPA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2010, 10:02 PM
  3. Oil Pressure Sender
    By My Car in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-01-2008, 04:36 PM
  4. SV8 oil pressure sender
    By roy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-10-2007, 03:19 PM
  5. Oil Pressure Sender Location????
    By HÝPÕ-5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 10:13 PM
