Results 1 to 3 of 3
Thread: changing clutch fluid..
    VY SS
    May 2009
    Default changing clutch fluid..
    My clutch fluid is filthy and i want to change it myself..
    Ive been told on the Ls1 its a pain in the ass to do and i was told the best method to use is the syringe method.
    Any one do this before? How is it done?
    Cheers.
    Nothing, at the moment
    Sep 2010
    yeah, you can do it the same as you would bleed the brakes on the car, its a bit difficult though as there is a small opening on the LHS of the bellhousing. you will need a 1/4 drive ratchet with a 13mm tube socket or a 1/4 ratchet with uni joint and tube socket (could be wrong with the size as i did mine ages ago) and bleed it like you would bleed the brakes. HEAPS easier on a hoist!
    VY SS
    May 2009
    Yeh i have tried it that way before, not easy very messy and like you said its much easier on a hoist.
  1. clutch fluid on pedal
    By todro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2008, 11:15 PM
  2. How to change clutch fluid
    By newtownbob in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2008, 08:38 PM
  3. Changing brake fluid
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2006, 10:44 AM
  4. Clutch hydraulic system losing fluid.
    By dephilile in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2006, 07:58 PM
  5. Changing Clutch Fluid
    By Johnny_V in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-06-2006, 08:27 PM
