Hi guys. Just done a return trip from down near Apollo Bay (Melb) and on returning I had to pull over and use my Hazard lights only to find that they would not work. What I did find though was if I pushed in the hazard lights switch and then turned an indicator on, only then would all hazard lights flash. So ok. maybe its a blown fuse so I thought Id check it on the way home. But then a bit later on I noticed that whenever I tried to turn my headlights on, or just flash my high beam on the engine wanted to stall.
Whats going on here. This is really doing my head in.
Thanks guys. Hope you can help me here .
Cheers all .
Peter
earthing or alternator regulator problem? its a very different car but i had a similar problem that when i turned my headlights on and drove in my VC Valiant the enging would wanna cut out... turns out it was a dodgey regulator... but please wait for someone to correct me as they are VERY different cars![]()
It will be a dodgy earth somwhere. Had the same problem with a jeep. Indicators funtioned the wipers at the same time. Annoyoing when not raining.
