Results 1 to 8 of 8
Thread: Difference between ABS and nonABS diffs???
    VY executive ute s1
    Jan 2009
    Default Difference between ABS and nonABS diffs???
    Ok, so i know one will do the whoel ABS thign and one will not, but im looking to put a LSD in my V6 ute and want to know if its ok to use a SS diff which can run abs?? is it a huge deal weather i get a ABS diff or not?? I havnt got ABS, and i dont plan on running it either
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    VY SII HBD Calais L67
    Dec 2006
    The internals of the diff are the same. It will bolt straight up and will run fine
    VYII Calais L67
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    internals are the same but stronger. if you don't have abs, and you buy an abs diff, you just won't be plugging the abs sensors in.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    VY executive ute s1
    Jan 2009
    deffinatly dont have abs. known from experiance with idiot sydney drivers!!
    cheers guys!
    ve sv6
    Aug 2010
    the abs runs off the inner cv shaft joint on the axel, there is a toothed wheel that the abs sensor works on, so maybe apart from a cast lug that the sensor sit in it the same abs or not.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Please post a pic of your engine bay. I thought ABS was standard equipment??????????
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    sp001in's Avatar
    MALOO R6
    Jul 2005
    QLD
    abs is not standard equipment on all vy's. my ute does not have abs either. I have just upgraded from a V6 LSD with 3.08 ratio to a VZ SS 3.07 LSD diff. only difference is stronger internals.
    also the vz diff has the abs plugs on it. but I just didn't need to connect them. it is still a straight swap.
    PS selling my old LSD v6 3.08 diff for $100.
  1. Vk diffs
    By Pez in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-05-2010, 04:20 PM
  2. irs diffs
    By idb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2009, 12:33 AM
  3. diffs
    By brend0n in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-05-2008, 09:04 AM
  4. Diffs
    By holden08 in forum V8 Development and Modification
    Last Post: 20-03-2007, 11:44 AM
  5. diffs
    By commnz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2005, 10:23 PM
