Hi Guys,
The cig lighter / socket was working when i got the car, however it just randomly stopped working :S i have checked the fuse nd replaced it but still no luck if anyone has any information at all it would be greatly appreciated
Thanks
you may need to check to see if its plugged in underneath the center console where there is a connection
yup right under the power window switches is where the connection is is your finding it hard.. its a little one with a brown and yellow wire in it.
if that doesnt work then you may need to take out the whole ciggy plug and make sure the wires havent come loose on the actual plug, as this same thing happened to mine a bit ago
thanks alot guys...ill give that a go nd let you know how it went![]()
