Hi Guys, I've serviced my old carVR Transmission, by oil change, and gasket/filter. My question is
1. Is the VY tranmission service same? meaning. Remove tranmission sump, collect old oel, remove old filter (and that steel ring thing), add new steel ring thing, slap in new filter, wash out sump (cleaning magnet too), add new gasket, screw back on transmission sump (carefully not to break gasket), Add transmission oil from engine bay, (apprx 4Litrs and from memory is DX3(but ill look in manual)).
2. Anything else you need to do to a VY Tranmission when taking it, out anything I should look for?
She's just hit 98,000k's, got her on 64,000, so im just gonna change it for my piece of mind.
Cheers Fellas
yes it is the same i dont change the metal ring if it is stuck as it can cause metal ending up in the trans and you can tighten the bolts fairly tight about 30-40nm 40 being fairl high you dont need to clean the pan the metal on the magnet wont come off but do it if you have to
same as VR in terms of servicing oil.
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
i agree you should clean the magnet. yes shavings probably wont dislodge in the transmission but i still think that a clean magnet will pull new metal bits out of the fluid better then a dirty one.
To clean magnet, wipe with clean lint free cloth. Always works for me.
