Hey guys i did a search but couldnt quite find the right answers. I got a VYII Ute (V6) and want to lower it.
-Will King Superlows all round make it sit even? or will i need to go lower in the back?
-With superlows will i need to change my shocks? need a camber kit? roll my guards? (Got 245/35/19)
-And in the King Spring catalogue it says VS Sedan Super Lows has the same part number as VY Ute ultra lows. I can get a pair of these real cheap so if they are the same ill grab them.
Thanks in advance
ur best bet is to call someone like burson auto parts and tell them what height you would like it to sit at and they will call king springs to find the right setup. I think with mine i had to go lower at the back to get it to sit even. I had standard shocks for awhile ended up puttin super low rear shocks in but and its alot better. I have a camber kit just for piece of mind. and i have rear guards rolled fronts are alright.
and i have SL front and SSSL rears.
hub to guard heights are aprox frt khfl-47sl 350mm, khfl-47ssl 335mm rr khrl-127sl 365mm, khrl-127ssl 350mm and khrl-46sl 335mm.
coil over the rear. did it too mine. love it.
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
