Does anyone know if VZ calais tail lights will fit into a VY berlina? Are any mods required?
Yes they will fit, (if its a standard rear end) and no, no mods required.
If you have a VY base model, Executive upto Acclaim or SS, you would need a VZ Exec/VY/VZ Berlina/VY/VZCalais bumper bar, and a hole drilled into the tail light housing/rear quarter panel or a little plastic pin snapped off the tail light. The Standard VY has a hole for one of these pins, but the lights have two pins - so either drill the car, or snap off the pin
Basically only the Berlina/Calais got the bigger lights in the VY range, and in the VZ range they all got them except the 'SS' which had the smaller lights, like the VY's.
If your rear end looks like this, then yes, bolt/screw in job...
Pic courtesy of MYDZYR, who needs to resize his imagesrandom google image
Thanks Zeussy!
Yep thats my rear, and these are the lights
I know a lot of people don't worry but legally (ADR's) you are supposed to add reflectors when you fit those Calais lights as they don't have reflectors built into them like your current Berlina ones.
VY2 calais and VZ Berlina and Calais have the reflectors built into the lower section of the bumper bar.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Had no idea about that surfwagon, I reckon the chances of getting pulled up are prretty slim.
Cheers for the heads up!
yeah i wouldnt worry about it....until you go for a RWC then you need to swap your lights back or stick some on (take them off after) i learnt the hard way lol
Looking to buy VE super sport replica's
[QUOTE=Zeussy;1658893]Yes they will fit, (if its a standard rear end) and no, no mods required.
Not all VY's executives just have one plastic pin on their tail lights. There was a revision around the time series 2 came out that added the extra pin to the outside edge on the bottom of the light. You'll also notice the reflector inside the tail light that covers the stop light globe is also deleted. I've got a late 2003 series 2 and it has the 2 plastic lugs to locate the rear light assemblies and no reflector in front of the stop light globe. I have a series 1 S pac rear light at home and it has one plastic locating pin and the reflector covering the stop light globe.
so the vz calais tail lights are bigger then the vy base model?? so the vz lights wont fit unless you get a new bumper??
VY executive, acclaim, S and SS models all use the smaller tail lights as do VZ S & SS models.
VY Berlina, Calais and VZ Executive, Acclaim, Berlina & Calais all use the larger style tail light.
Can anyone tell me where to buy the vz calais reflectors? Is it a single strip that I can fit to my bumper?
VY Berlina 3.8L stock as a rock... and staying that way
