Results 1 to 2 of 2
Thread: how do you remove the plastic side trim vy clubsport
    VY Clubsport
    Sep 2010
    adelaide
    Default how do you remove the plastic side trim vy clubsport
    can anyone please help me not to sure how to remove the plastic side trim that the rear speaker wires run along in a VY clubsport. I need to get them off as i will be putting 6x9 speakers in the parcel shelf and need to cut into the speaker wiring.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    scuff panel - 4 torx at front door under plastic cover, 2 torx at rear door, also have to remove plastic trim around seat rails. It also helps to remove the lower B pillar trim (2 clips, pry it outward 1-2" from the top at each side)
  1. drivers seat plastic trim
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2010, 12:47 AM
  2. Best way to paint vl berlina plastic trim
    By vl_2010 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2009, 10:07 PM
  3. vn door trim plastic lock
    By 1990vnwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 11:54 PM
  4. WTB VP rear window top plastic trim
    By calais_cruzin in forum Swap / Wanted to Buy / Trade
    Last Post: 28-02-2007, 12:33 AM
  5. how to remove the out side plastic door trims ?
    By steve_o_85 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2005, 05:50 PM
