Results 1 to 9 of 9
Thread: Climate control unit losing vacuum ?
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Default Climate control unit losing vacuum ?
    Driving along, if I put the foot down a bit (say going up a hill or overtaking) I seem to lose a/c blower to the face.
    I had a similar situation in a VS Calais - and it's the solenoid controller that sat under the stereo.
    Has anyone been here with the VY ? Any tips would be appreciated!
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    VT V8 Calais
    Mar 2007
    Jun 2005
    Brisbane Bayside
    Sweet - looks like a very similar unit to the one used in the vs - but in a more accessible position. Thanks for that.
    Jun 2005
    Brisbane Bayside
    I finally got arouns to installing brand new actuator solenois control - no change
    I have checked the one way valve on the vacuum line in the engine bay - what's next?
    Hot House VY SS
    Jan 2010
    Hey mate I have a similar problem but is intermittant. From doing some searching, it may be the vacuum valve
    Heres a pic of the ventilation system, may help
    Also have a read through this post
    VT Climate Control (Vacuum??) Problem?
    Jun 2005
    Brisbane Bayside
    My check valve is ok - will check the line up to and including the tank - and look into the 'vacuum valve' (if I can find it) - but if it looks like being one of the three actuators being faulty, It probably goes into the too hard basket as it's not that big a problem (at this stage). Thanks for the links/infos
    VY II Calais
    Nov 2008
    can anyone tell me where the engine check valve, vacumn tank and vacumn valve are in the VYII, everyone tells me that there is a black valve in the engine bay between the engine and the firewall but I can't find it, sorry to be a pain.
    Jun 2005
    Brisbane Bayside
    The check valve is - as you say - between the engine and the firewall. It is half black, half white and has like a black 3mm (?) tube going out each end.
    Hot House VY SS
    Jan 2010
    Vacuum tank is behind the glove box on the left, and I think the vacuum valve is behind the stereo or fan controls.
    Have a good read through the thread in my above post everything you need to know is in there
  1. VT Climate Control (Vacuum??) Problem?
    By Zeussy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2011, 07:30 PM
  2. Climate Control Vacuum Probs VY Calais
    By oztech007 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-09-2011, 06:52 PM
  3. Replies: 10
    Last Post: 27-04-2010, 10:00 PM
  4. VT climate control fault (vacuum?)
    By tom26 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2010, 05:39 PM
  5. VYII Climate control vacuum leak help
    By BERVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-10-2008, 09:53 PM
