Good morning all!
I'm really hoping someone can help. My dad has a VY ute and the interior light and horn have stopped working for no reason. Have checked and replaced the fuses and this didn't fix the problem.
Any ideas????
Thanks in advance!!
Kim
Mabe the light attivators in the doors are not operating properly ?. HORN I would check the steel plugs to the horn are pushed on and properly and both still making a connection. Other than that Auto Electrician.
has your dads stearing wheel got controls for the headunit on the wheel? if he does and he trys to change song/ change volume, and it fails to work. then he needs a new clock spring. but usealy when you break a clock spring, you lose air bags as well and a fault comes up the dash. take it to an auto lecky.
want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
