Hey guys just wondering if i can use this to pull my back wheels in?
Because i lowered it and saw this and looks like it could pull the wheels back in
It's a rear toe control adjusting arm. Not used so much as to adjust camber as it is to control toe during camber adjustment which is done bye the rear trailing arm/ control arms to K frame bushes
VYII Calais L67
alright thanks mate. So not much point trying to adjust it?
It needs to be adjusted by a pro in conjunction with the camber kit if fitted. When camber gets adjusted, toe is affected and thus needs to be brought back to spec
VYII Calais L67
go get yourself a 4 bush camber kit. mine cost me $650.00 plus installing and all wheels realined.
want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
You can get nolathane camber kits off ebay for $125
