Results 1 to 13 of 13
Thread: 20inch rims Vy S pac
    VY S Pac Series II Supercharged L67
    Mar 2010
    Wollongong
    Default 20inch rims Vy S pac
    Hi guys, im looking into putting some 20inch rims on my 2003 Vy Spac.
    I was wondering if they are a legal size and if they would void my insurance?
    I have the stock FE2 at the moment but i find theres sooo much space between the tyre and gaurd with the stock 17 inch rims. Would the 20inch rim close the gap or will it just look like im 4WD-ing?
    I was looking at either of these 2:
    products
    products
    would they fit?
    Cheers guys!
    VY Executive S2
    Jan 2010
    s pacs dont have fe2 its just standard suspension thats why you have such a big gap (:
    Mar 2010
    Wollongong
    ohh. i checked the badge under the bonnet that has all the engine and suspension specs and it says fe2? soo confused lol!
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by danieLOL View Post
    the s pacs come with fe2 not standard suspension.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    Mar 2010
    Wollongong
    cheers thought i was right. so does that mean if i put the 20's on the gap will close? or am i better off just lowering it with the current stock 17's?
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    to be honset im not quite sure. when i got my 19s from 17s the overall diameter only changed by about 10mm i think so thats not much differance.
    Vy Ute, V6, Manual
    Mar 2009
    East gippsland Vic
    the gap might close by around 5mm but you will be looking at it next to less tyre sidewall so it will look bigger
    Mar 2010
    Wollongong
    cheers guys. heating the coils isnt a good idea is it? i wanted it about 40-50mm lower. have you guys got a rough idea on how much pedders would charge to drop it that much? ill have to go see them this week
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by Vy S SC View Post
    products
    products
    would they fit?
    Cheers guys!
    Daniel is incorrect. FE2 was fitted to your series 2 VY S. Fe2 was standard on all VY series 2 SS, S, and SV8 sedans.
    The tyre to guard gap is larger on the FE2 cars for the VY and VX models than it was on the VT model.
    If you fit 20 inch rims and tyres you must :
    - retain the minimum tyre load rating stipulated for your car on the tyre placard. If you put a lower than minimum load rated tyre on the car it is illegal.
    AND
    - ensure speedo accuracy is maintained which means the tyre diameter of the replacement tyre MUST be the same or very close to the diameter of the standard 235 45 17 size tyre fitted to your car ex factory. These are approx 645 mm in diameter which means that to retain speedo accuracy you will need to find a 20 inch tyre that fits the rim in approx 645 mm diameter.
    You will not reduce the gap to the guards with a 20 inch riim and tyre unless you put on a much larger diameter tyre. However, this will throw out speedo accuracy (it will under read)and render the tyres illegal.
    You reduce the tyre to guard gap by lowering the suspension with lower springs - not by fitting illegal oversize tyres.
    Many of the 20 inch set ups I have seen on VYs have larger diameter tyres to achieve the minimum load rating needed. This renders the speedo reading inaccurate. Top get the correct width/diameter you need a 30 profile tyre on 20 inch rims. If you increase the rim size you must reduce the tyre profile to compensate, ie. 17 inch 45 profile , 18 inch 40 profile , 19 inch 35 profile, 20 inch 30 profile.
    If you run a 19 inch on the VY you will have no trouble getting the correct tyre to cover both the load rating and correct diameter to retain speedo accuracy.
    235 35 19 diam approx 647 mm
    245 35 19 diam approx 655 mm
    To achieve the minimum load rating on a 20 inch rim (8 or 8.5 inches wide) you will probably need a 245 30 20 tyre. It will depend on the brand though and you need to check the load ratings carefully. This will also give you a tyre diameter of about 655 mm which is very close.
    With respect to vehicle insurance, you MUST advise your insurance company of a change of wheel from the standard type or size. This is a vehicle modification and you are required to disclose all vehicle modifications to your insurer. If not the insurer has the right to deny any claims you might make in future whether or not the claim was affected by or related to the modification. When you have decided what changes you want contact the insurance company to ensure they will continue to cover you if you make the change. Then disclose the modification to the insurance company when it is done and make sure this is acknowledged in writing.
    03 VY_S
    Jan 2008
    hey bud check out this thread:
    V6 vy
    also just my 2 cents.....my series 1 s pac has fe2 on the plate under the bonnet also i put 19's on mine (with fe2) and the tyre did fill the gap a little (but i had little 225/50/16 on originally), if you want some pics i can get some
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    i got mine done by pedders(townsville) about two years ago SL(touring springs) front SSL (sports ryder springs) rear an struts an rear shocks to match (touring) plus bushers for roughy $1100 drive in drive out
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    i have 20's with a 35mm profile tires. also got it lowered on Lovells ultra lows. never had a scrubing problem.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VY Executive S2
    Jan 2010
    :/ really? my mates s pac sits as high as my exec did when it wasnt lowered... strange..
  1. do VE GTS 20inch rims, fit on a VS irs??
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2010, 09:46 PM
  2. Cheap 20inch Rims
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 01:33 PM
  3. 20inch rims on vs
    By smoken-v8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 03:13 PM
Tags for this Thread
