Page 1 of 3 123 LastLast
Results 1 to 25 of 69
Thread: Just a general fuel consumption question
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Default Just a general fuel consumption question
    Hey guys,
    normally when I do long distance driving...like highways, etc, my vy's fuel consumption sits on, at best,
    8.4l/100kms...
    or when i take it easy around town it sits on about that maybe moves up to like 8.6l...
    but just recently I changed fuel filter, started running it on premium, cleaned the throttle body
    and cleaned the injectors.
    now at best I can get her to sit on 7.4l/100kms...
    is that normal?? because I've never seen it so low is all...
    thanks,
    kc
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Sounds pretty good to me, dont jinx yourself.
    My SS is sitting on 16.2ltr/100km atm.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by kcpwns View Post
    Hey guys,
    8.4l/100kms...
    thanks,
    kc
    When i first got my VX, I Stuggled to get 600kms to a tank. So I Did a full service, GM Fuel Filter, GM Air Filter, 10-30 OIL, GM Plugs, GM Leads, GM Oil Filter. Be Sure you dont have your lights on all the time.
    I now get 700kms to a tank. I Found the GM plugs the best, I tried Bosch plugs and lost 100kms to a tank, no idea why. Also found running your lights all the time looses 100kms to a tank also.
    Once all done just be easy on the throttle, i rarely go over 2500rpm. unless i need to boot it to merge over.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by edals View Post
    Something is seriously wrong electrically if your headlights make your fuel consumption increase by 16%. Running the air con might cause an increase like that, but not something like the headlights that only draws ~100Watts.
    I run my headlights and aircon all the time and get 680kms (11L/100km~) from a tank. On the freeway it sits on about 7L/100km which would be about 1000kms to a tank.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by TMM View Post
    Yeah Im not sure mate, Its just something i noticed but a guy with a new lancer at work did the same and said it took about 80kms off his tank having them always on. Might have been a week that i was more heavy footed, but it does affect it.
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    my VY v6 on gas used to sit at 15L/100kms.. consider yourself lucky
    Check out my ride!
    2002 VX II Acclaim
    Aug 2008
    251rwkw VY SS
    Mar 2010
    I have a mafless tuned SS and I'm sitting on 12.6L/100kms. I live in St Kilda (Vic) too so it's not like I'm always on highways.. Highest mine will go is 15L/100kms and that's when I'm punching it everywhere... 7.4L/100kms is friggen awesome dude.. And as for this headlight thing everyone is talking about.. I have HIDs and am a Friday night cruiser and I don't lose anything out of my tank.. Being a sparky too I highly doubt you'd be losing that much fuel from your headlights! Air con I could relate to but not headlights........
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    That's one of the funniest things I've ever read on this forum. Driving with your headlights on will do SFA to your fuel consumption. Best you don't turn your stereo volume up over 3 as you won't make it to the next servo.....
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by wikky View Post
    Righto, GO Try it your Self, Its what i found in the VX, THe VR, and a Mate at work with his 2010 Lancer,
    Ranging between 50-100kms to a tank lost them being on all the time.
    And Why is Volvo using energy efficient head lights ? cause running lights does affect it.
    Do a test, Have at car at idle, then switch your lights on, listen to the tune change to the engine.
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i only get 400kms out of a full tank but its all town driving..
    in my VR i did a test like that but it was more of like lets see how long it would take to drain our battery at idle (so we could run air con) after like 45min car just jumped up to 1000rpm for a little while then dropped
    VZ SSZ
    Mar 2008
    Here
    I do drive with my headlights on quite often and no, it doesn't affect my fuel economy. When I start my car then turn on the lights, no, there's no change in the 'tune of the engine'. My scan gauge doesn't even show a change in anything whilst the car is idling or at speed. I've also noticed no change in fuel economy in my Hilux 4wd or any other of our company fleet vehicles, ranging from povo Omegas, SV6 (SIDI & Non SIDI), Wagons and sedans, SSs, povo Falcons through to T6s. Our company policy is to drive with headlights on (as a safety measure). I've never once noticed reduced economy due to having headlights on.
    Oh, and I just looked up about Volvo using more efficient headlights. They're talking about light and life efficiency, nothing to do with fuel economy.
    251rwkw VY SS
    Mar 2010
    Mate trust me, There is no way headlights can decrease the amount of fuel you get out of the tank.. They don't draw anything near enough to be able to do that... As wikky said.. If that was the case you wouldn't be able to turn your stereo up past 3 because the stereo draws so much more! All these new cars that have day running lamps would surely be affected too? Like I also said in my previous comment, I have HIDs and spotties, and I do a lot of cruising with friends at night time with both the HIDs and spotties on.. And don't lose anything out of my tank..
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Edals, if having the headlights on all the time affects your fuel consumption, there is something SERIOUSLY wrong with your alternator, battery or entire electrical system.
    Either that or you are consistantly ruining the validity of your testing by flat-footing it with them on, while driving like a granny with them off.
    Last I remember, only the engine had injectors, not the headlights.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    ಠ_ಠ
  15. #15
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Just what i found with 2 different commodores, and a work mate with a brand new lancer. Just thought i would mention it.
    And no i dont flog my VX, I rarely go over 2300 RPM, the Mrs has found the same in her VR, and my work mate is the last person to rev a car.
    So believe or don't, like anything
  16. #16
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    ah...yeah that doesnt sound right mate...and that 7.4l i had was with my lights on...
    maybe there something wrong electrically with ya ride?
  17. #17
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Last time im going to post this, MY VX, MRS VR, WORK MATES 2010 LANCER with 12k on it. All effected by running headlights all the time. All between 50-100.
    3 different cars. So i dont know if the lights cause drag or what here, but out of 3 cars, we all found it was effected by it. By 3 different drivers. over a few tanks to check if it was just fuel, when we all run 95 in them. All running the same freeway routs every day.
  18. #18
    251rwkw VY SS
    Mar 2010
    Why post if you don't want the right feedback? You have people that KNOW about cars here telling you that it is IMPOSSIBLE to lose 50 - 100kms out of your tank just from your headlights unless you have an alternator problem yet you persist on telling us about other people and their cars having the same issue.. The only way your headlights can possibly reduce the kms you get out of your tank is if you have an electrical fault, or if you have the wrong size pulley charging your alternator forcing it to work harder/chew more juice, and even then losing 50-100kms is extreme mate.
  19. #19
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    sorry mate not having a dig...just sayin ya mite need to check it...
    cus i dont think having ya lights on would make a noticeable difference to fuel consumption...
    like fabregas said it mie be alternator problems
  20. #20
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Im Not having a go, Its just what 3 of us have found while running the cars with headlights on.
    I Dont know what the go is, Its what we have found, 3 different cars, 3 different people, everyone can have a say. Just having a extra 110 watts of extra drain thats all. Could be a matter of things that have caused it while we tested it. Just like having a polished car can benefit fuel eco. people will say thats a load of crap, others say not. like anything. I posted it saying its what we have found to increase fuel/kms a tank. As for the alternator, mine was recently rebuilt and was same before and after, so i dunno. Same with the VR. Everything on the cars are OEM parts, no performance changes not even plugs or leads.
  21. #21
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    finally somebody else that thinks this.
    im not going to agree with your high figures but it definitely drains more fuel
    the same thing in my pajero.. turn the lights on and it lags at idle for a sec then returns
  22. #22
    251rwkw VY SS
    Mar 2010
    If your alternator was rebuilt it might be a good idea to get it checked out elsewhere to see if they have installed the right pulley sizes.... Like I said previously the wrong size would work the engine harder causing more fuel consumption. Are you having any battery problems?
  23. #23
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    dudes that think the head lights turn on don't effect fuel economy are IDIOTS! it loads up the alternator! It takes energy to make energy. thats why perpetual motion don't work. Bathurst this year you could hear them on the radios before the last pace car telling the drivers to shut off lights, blower fans etc to conserve FUEL! last time i checked they run these off of the ALNERNATOR not the fuel tank. The consumption is governor by how many amps your alternator is and the load you are putting on it.
    Making and running DUAL CHIPPED ECU SINCE 2010
  24. #24
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Well finally i see im not alone. It may not affect it as much as i said, could just be something that affected it also while we did tests, bad fuel, worse traffic on one day and better the next. just when we each did it we did have a affect on it.
  25. #25
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by bloodyricho View Post
    Bit early to be drinking isn't it? Last time I checked we don't drive around in V8 Supercars which use a massive amount of fuel. They also keep track of every last drop. Apples and oranges.
  1. General Exhaust/Fuel Consumption questions
    By Deutscher in forum General
    Last Post: 27-05-2010, 07:24 PM
  2. fuel consumption question
    By fergie_vs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 08:24 PM
  3. Fuel Consumption in relation to Service question ??? - please help
    By scalper in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-06-2009, 06:53 PM
  4. sub box general question / perspex?
    By mojo.jojo in forum Car Audio
    Last Post: 10-04-2009, 05:50 PM
