Results 1 to 7 of 7
Thread: Stereo Help
    vz ssz
    Jul 2010
    Default Stereo Help
    I was just wondering if some one in perth could actually help me remove my head unit, i spent a good 1-2 hours on it today and tried every thing to remove but just couldnt get it out
    Any help would be appreciated.
    Cheers brad
    90 mazda 323
    Oct 2010
    perth nor and lovin it
    you use a coathanger . Cut it into 4 lengths and insert them in the 4 holes in the side of the head unit and pull head unit out .
    onces its out ther's a diagram on your factory deck that shows you what plug is what
    VY II Adventra LX8
    May 2010
    i've had trouble with a few stubborn radios refusing to come out after using the pins and coathanger wire. i ended up using some long nails and pushed them inthe hole and towards the radio, i found after i got it out the spring wasn't quite depressing enough when i used coat hanger wire
    You fight like a dairy farmer.
    How appropriate. You fight like a cow.
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    useing the coat hanger wire can damage the pins. go to your local holden and they should be able to do it for you for free, also it will take them 20sec's to walk to your car. open your door and pull the head unit out.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    If you pay for my plane ticket from Brisbane RETURN. meet me at the front of the terminal with your car and I'll pull it out for you in 5seconds or less. turn around and jump back on a plane home.
    If you want my paypal details to deposit the funds for the ticket just PM me.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by Kingston_99 View Post
    Not if you make them properly with a notch.
    See here:
    Blaupunkt VY/VZ Removal Tool
    I've pulled mine countless times with my coathanger tool and the clips are perfect.
    vz ssz
    Jul 2010
    well spooin i got a better idea you pay for your own ticket and come over and do it
    cheers for the help guys i had been trying the coat hanger, tried nails, tried long skinny screwdrivers tried nearly everything i could think of so
    i went to holden to get it done and it took them 45 minutes to get it out, they said it was the most stuborn unit they had dealt with lol
  1. help with ve stereo please
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-12-2009, 08:23 PM
  2. vz stereo PLease help???
    By calais4life in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-12-2009, 08:54 PM
  3. VT Stereo
    By ducatis in forum Car Audio
    Last Post: 13-03-2006, 06:57 PM
  4. Vs Ute Stereo
    By SS UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2006, 08:07 PM
  5. VY Stereo
    By wheelz_27 in forum Car Audio
    Last Post: 20-06-2005, 08:15 PM
