Results 1 to 3 of 3
Thread: How to install new radiator for VY Holden Berlina
    vy holden berlina
    Oct 2010
    quakers hill
    Unhappy How to install new radiator for VY Holden Berlina
    Hey guys
    i need help with replacing my radiator.
    Can some one tell me how much does it cost for a new radiator.
    What all things do i need to change while changing the radiator.
    Do i need to buy any additional spares.
    And how do i install the new radiator please explain to me step by step
    Chris.
    VX S2 S-Pac
    Oct 2005
    Im sure if you were to do a search it will come up, its late so il give a quick attempt.
    unplug all the plugs to the thermo fans and pop the metal spring lock things then pull the thermo fans off
    un bolt any pipe attached to radiator (water inlet/outlet, trans cooling pipes etc)
    slide radiator up and out, it does get caught so u might have to pop one side out of the side channel first once it comes up a bit
    reverse for connecting it back up
    second hand a radiator is between 150-250
    new around 200 non genuine and probly 400 or 500 genuine as a guess
    As for spares, you'll need to refill coolant and water and could swap the pipe seals while your at it because they are cheap enough and u will have the pipes off anyway
    Good luck
    VR through to VX wrecking in WA, must get rid of these!
    http://forums.justcommodores.com.au/...res-vr-vx.html
    VY SII HBD Calais L67
    Dec 2006
    New radiator costs roughly $200- $300 Holden Commodore VY Holden Commodore VY & WK RADIATOR V6 9/02 - 8/04 AUTO / MANUAL
    I bought one of these for my VY but had to make some very minor changes to the thermo fan mounts because VY uses a slightly different thermo fan set up. No biggy, a trip to bunnings and a little strip of aluminium fixed all that Holden Commodore VT,VX & WH RADIATOR V6 / ALL ALLOY 50 MM RADIATOR
    VYII Calais L67
LinkBacks (?)
  1. 05-12-2010, 03:22 PM
  1. [VY] HID H11 INSTALL for VY Calais / Berlina / HSV adsl only!
    By sp001in in forum Holden Commodore How-To's
    Last Post: 26-04-2012, 01:29 PM
  2. how to install new radiator?
    By joeyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2011, 11:07 PM
  3. [VIC] Holden straight 6 - CRS SC14 install kit
    By mookschank in forum Parts And Other Items For Sale
    Last Post: 14-11-2009, 10:18 AM
  4. 99 berlina radiator fan won't turn off
    By skippyd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2009, 01:48 PM
  5. Radiator hose on VT Berlina
    By VtBerlina_3800 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2006, 10:53 PM
