Results 1 to 8 of 8
Thread: Trouble with the alternator, any ideas?
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Default Trouble with the alternator, any ideas?
    Hey guys.
    I don't actually own a VY, this is to help my uncle who has a completely stock VY commodore.
    So a month or 2 ago he was driving around and the 'check alternator' light flashed on. The next day the car had a flat battery, so he called RACQ and they came out. He checked the battery and filled it up with water because it was dry. So the car then started and he drove it around until yesterday when the same thing has happened. He couldn't drive his car that day and isn't sure whether it will be the battery or the alternator.
    any ideas? I'll talk to him soon to make sure what i said is all right.
    thnks VLC
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    VLC86's Avatar
    VL Calais
    Dec 2009
    Yeah, he might have to take it to the shop. Just trying to save a bit of money if it can be checked easily
    Hot House VY SS
    Jan 2010
    I guess the easiest way to see if the alternator is working properly is to put a multimeter over the battery while the car is running. If its anything different to 14 volts or so theres a problem with the alternator.
    In all honesty though it sounds like the battery is stuffed
    Dec 2009
    How old is the battery? I'd check the voltage with the engine running and see if the alternator is charging, shoudl be aroud 14 volts. You can also load test the battery put a volt mete ron it and crank the engine with the fuel pump fuse out and see if the voltage collapses. Alternator could just need new brushes and you can buy them and solder them in yourself.
    VLC86's Avatar
    VL Calais
    Dec 2009
    Yeah i was thinking it could be the brushes, they'd be easy to replace, just take out the regulator. Ill tell him to try the multimeter while the car is running.
    If the voltage is going down while the car's running then the alternator is stuffed, if the voltage stays regular then the alternator is charging it alright. It might be the battery is just old, no idea how long he's had it.
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    If the battery went too flat it may be permanently stuffed.
    Ronald Reagan (1986)
    VLC86's Avatar
    VL Calais
    Dec 2009
    well here a funny result to the whole situation...
    car is now running fine, apparantly the car was left on a slope with 1/4 of a tank of fuel left in it. And because the fuel pump wasnt getting enough fuel thats why the car wasnt starting..
    sounds odd to me, but the RACQ mechanic did all the tests including the alternator and battery and they all checked up fine. He checked the fuel pump fuse or something and that told him it wasnt getting enough fuel. Anyway car got a few litres of fuel in it and it started straight away. Can't explain why the alternator light kept coming on but we'll wait to see if it happens again
    thanks for the help fellas
  1. Pitching exhaust ideas (custom ideas)
    By JSTCOZ in forum General
    Last Post: 02-10-2010, 06:32 PM
  2. My 1998 VT Executive, IDEAS IDEAS
    By 98VTExec in forum General Discussion
    Last Post: 22-09-2009, 01:10 PM
  3. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  4. Big trouble i think
    By petesvns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2005, 07:48 PM
  5. Just Trouble
    By dougie tas in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2005, 10:18 PM
