Results 1 to 10 of 10
Thread: EGR and PCV VALVES
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Default EGR and PCV VALVES AND IDLER PULLEYS
    Howdy - my stock Exec is currently using 11.2l/100 which is okay but thats mainly country driving it like a total nana!
    I have progressively in the last 6 months replaced O2 sensors (bosch) ,plugs (NGK) , leads (Eagle) ,fuel filter(genuine) ,recharged K&N air filter and changed engine oil and filter( 10/30 ). Also cleaned throttle body. This has made the V6 smoother at idle and acceleration but has not reduced fuel use as I would have expected. I just found a thread about Idler pulleys being a possible cause so will check those. Is it worth checking the PCV and EGR valves and if so how do you do that?
    Dec 2009
    Quote Originally Posted by maccasparks View Post
    Sounds like you have replaced the usual items that cause this. I can't see how the EGR and PCV valves would could have an effect. Have you checked the engines compression and is the lockup torque converter working?
    VY V6 Wagon
    May 2009
    Tauranga NZ
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Okay - I checked idler and tensioner pulley bearings and they are all free and smooth but the top idler is a little noisey . Can I just replace that one and best to get genuine one? Also any hot tips on fitting new pulleys?
    Dec 2009
    Yes you can buy them individually from Holden and I would probably stick with genuine parts. If your talking about the pulley on the belt tensioner remember the bolt is a left hand thread so don't try to undo it with a lot of force in the normal direction. If the pulley on the belt tensioner that is there is a genuine one for a VY it should be made from metal and in this case the other optins are to go and buy just the new bearing and fit that to the existing pulley or what I have done in the past and it worked just fine is to take out the old bearing and then pick out the dust seals carefully so as to not damage them with a scriber and re pack the bearing with grease and reassemble it. I've also used this trick on an alternator and after repacking the bearing had no play and made no noise. If you repack it and there is excessive play it shoudl be replaced as soon as possible. You will probably need some circlip pliers as the bearing is most likely held in by a circlip (I've only removed the bearing from a VN pulley so I am assuming there held in the same way).
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the other part you can try to replace is the ecu temp sender. from memory, VT and up had a combined dash and ecu sensor, but please correct me, im just going off memory here!
    if its sending the wrong temp to the ecu, it still operates in open loop affecting economy
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by ephect View Post
    That is correct
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Thanks for that Ephect
    So where is this senor - how do I test it and what does it do??
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the sensor is located on the bottom half of the thermostat housing, it is roughly 20mm wide and will have a plug on the end with 2-4 wires (not 100% on how many wires), which simply unscrews from the housing.
    with a multimeter you can test the resistance and pooring hot water over it, it should change. i dont know what resistance at what temp it should be, but generally economy is effected if its not operating correctly, telling the ecu the temp isnt right and it runs in open loop mode, pumping in more fuel on its base maps due to it thinking its cold. Now because you've replaced most things that a major affect on economy to me its logical to replace this next.
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Does the ECU temp sender also do the temp on digital dash display - when u press mode and set and turn key on and go to "coolant temp" ?
    It was showing 67 degress and when I held a digital thermometer on to the outside of the thermostat housing it showed 52 degress . Close enough yeah?
  1. Are the valves gone?
    By quimby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2010, 09:07 PM
  2. tx valves
    By cinndaz044 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-12-2009, 09:59 AM
  3. Do I have worn valves?
    By 89berlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2009, 01:15 PM
  4. PCV Valves
    By 85berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-08-2006, 01:34 PM
  5. valves
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2006, 12:18 PM
