Ok Im replacing some of my doors and I just had a few question:
-How exactly do you remove the door hinge pins? I kind of understand how to do it but just looking for some extra tips.
-How should I go about inserting my original door lock/handle in the new replacement? with this Ive for no idea.
Also If you know of any other factors I should be consider, please let me know.
cheers James
Ok ive been able to remove the top pins on the doors, but im having difficulty remove the bottom hinge pins. Cant get a good grip on them with the plyers, Can anyone shed some light?
If they are the same as vt use a flat screw driver and tap the bottom pins from below upwards.it's easier to do the front doors if the guards are off.
All figured out, much easier then I thought, I got them off without the use of the special tool. Its just all the stuffing around with door locks and trims which took time.
thanks for the help
