Tried pushing CD button,but keeps staying on radio.
The only thing that looks promising is when i press EJECT it idles for a while,
it says"ejecting all discs"
This action does'nt recover any discs inside(6stacker) and puts me back to radio.
Hope this is'nt a major problem,any help is appreciated!
Only happended after changing the battery yesterday......if that helps.
I used to have varying problems like this with my 6 stacker blaupunkt.
Try this:
1) Remove the radio fuse and leave for 5 minutes, then re try
2) Or try removing the battery again for 5 minutes or so, should have the same effect
3) when mine used to jam i would try the eject all disc trick by holding the eject down,
4) or try loading or ejecting again and if it fails grab another cd and try and put it in as it might dislodge one that is jammed in the mouth of it
hope that helps
holterman23, how did u get on? I've got exactly the same problem.
Thx.
There's another related thread here by the way.
Heres how 2 remove jammed cd's from Blaupunkt sterio.
Any luck.....in the end I got rid of it and got a sony bluetooth mp3 unit which is much better, it used to do it all the time.....mine used to say CD Error and then return to the radio, the forcing another one in the mouth trick used to like reset it or something and it would just spit them all out then and start again.
After unplugging the battery, i'm now getting the mech error. I might need to start disconnecting the fuses now. Worked for someone else on another thread.
