Results 1 to 6 of 6
Thread: More trouble with my vy
    VZ Ute
    Jan 2010
    Wollongong
    Thumbs down More trouble with my vy
    I noticed when i got my exhaust i could hear the gears holding revs for too long coming out of first and into second. It sounded like it was slipping epically (automatic transmission) and when i manual select gears it changes gears by itself well thats what it sounds like. Im thinking its the torque converter or shredded second gear?
    Any help or suggestions to what it is will be very greatful thanks.
    sorry officer..thought you wanted to race.
    2008 VE SV6: 2004 VY II R8 Maloo
    Aug 2010
    Darwin
    Whens the last time you got that auto serviced? It *might* be as simple a fix as that.
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    even check that the tranny fluid is high enough can 'fix' these sorts of things, and certainly the best place to start. Of course, if it is low (even if a top up fixes it) you need to investigate why it was low ...
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Burnt ATF probably. Typical signs of burnt ATF is that the shift is delayed, then when it finally shifts it really jolts/slams it into gear. This is most prevalent on the 1st-2nd shift.
    Another sign is when you are in 1st at WOT and manually select 2nd, if doesn't shift until you let off the throttle.
    Don't manually downshift your stock box unless necessary (e.g. towing something heavy up a big hill), otherwise you will cause excessive wear on the box. Up shifting should be no problem though as long as you are at WOT.
    VY 2003 "HBD" Berlina
    Mar 2010
    Adelaide, SA
    Quote Originally Posted by TMM View Post
    Excuse my ignorance, but what is WOT?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by boordy_23 View Post
    Wide Open Throttle (foot flat to the floor)
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  1. vu ac trouble
    By aussiecarguy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2010, 08:09 PM
  2. Amp trouble...
    By VTCommy in forum Electrical Wiring / Questions
    Last Post: 11-10-2009, 04:42 PM
  3. Sub Trouble
    By B.C in forum Car Audio
    Last Post: 30-08-2006, 09:09 PM
  4. Vn Trouble
    By Stewart1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2005, 08:21 PM
