Results 1 to 9 of 9
Thread: VY king spring squeek
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    Default VY king spring squeek
    Hey guys,
    About to get a VY which has been lowered with King springs, I had a mechanical check (and drove it myself) however, when going up a curb or turning, there is a creek noise from the front LHS, the mechanic reckons this won't lead to any problems as could be the rubber seal/lose bolt.
    What do you reckon it could be?
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    i rekon its the strut top mount bearing /cushion. Buy a pair from ebay about $100 easy to change out, you have to remove the strut assy & compress the spring with a spring compressor tool then swap over the top bearing/cushions
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    96 VS SII 5.0 Calais
    Apr 2009
    Melburn
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    Apr 2009
    Melburn
    ah probably more around 150+, it depends what strut top mounts you buy, and if you bother to fix it yourself.
    as COLGF said just get them off ebay. nolathane and super pro make them, ensure they come with new bearings.
    also a rattle gun makes short work of removing the nut that holds them onto the shocker.
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    Dec 2009
    I'd also suggest checking the condition of the front sway bar link pin rubbers.
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    From what I could gather, the guy that did the mechanical inspection, seemed to think it was the "rubber seal" which is this - Strut Top Mount & Bearing Kit Holden Crewman Ute VY VZ (eBay item 120650639310 end time 22-Dec-10 15:37:09 AEDST) : Cars, Bikes, Boats
    I'm hoping it's that and a quick fix, he also said it could be because there's no lubricate on the bearing.
  1. Been given a set of king spring for my car-just not sure if they will do the job
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 02:02 PM
  2. [QLD] VT-VY King Spring SSL. F & R
    By SuperSixty6 in forum Parts And Other Items For Sale
    Last Post: 05-10-2009, 10:27 AM
  3. Help with King spring Models
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2009, 03:52 PM
  4. King Spring Question
    By VIPVT in forum General
    Last Post: 09-02-2007, 09:58 PM
  5. King Spring Superlows
    By Jimboss in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-02-2006, 08:54 PM
