Results 1 to 5 of 5
Thread: Intermitant Knock when turning
    Nov 2003
    Default Intermitant Knock when turning
    Hi All,
    I own a 2003 VY station wagon and very intermitantly their is a knocking noise coming from the front end of the car. This only happened when I turned left.
    The steering wheel wasn't in full lock either.
    I have previously put in posts about the car going to the left when you let go of the steering wheel.
    Do you think both faults are related to one problem?
    Regards,
    Arty
    VY S
    Jan 2008
    Wellington, New Zealand
    Hey
    Check all your suspension bushes, wheel bearings and strut tops.
    Cheers Daniel
    vy ss ute
    Feb 2010
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Maybe the strut top bearing if it makes the noise while stationary but turning the wheel, otherwise maybe the shock if it makes the noise while stationary but bouncing up and down without turning the wheel. Check the other bushes around too though and mabye even the steering rack(?), and that the wheel isn't scrubbing. If you get stuck Pedders still do a $14(?) safety check I think, so that might be an easy way to get an answer. Good luck with it
    Nov 2003
    Thanks guys.
    It only does it when I turn.
    It has only happened once.
    I think I'll go to peddles to see.....
    thanks guys,
    Arty
  1. vp v6 intermitant starting problem
    By racean69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2011, 12:19 AM
  2. intermitant fault
    By crw414 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2010, 12:27 AM
  3. intermitant cutout please help
    By vs-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 06:52 PM
  4. intermitant Acc issues
    By -=ApheX=- in forum Electrical Wiring / Questions
    Last Post: 12-02-2009, 10:22 AM
  5. intermitant engin fail
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2004, 01:47 PM
