Results 1 to 10 of 10
Thread: Cv joint failure
    VX s pac manual
    Nov 2009
    South West Sydney
    Default Cv joint failure
    My brother owns a VY SS ute he has just had the second tail shaft CV joint fail within the last couple of months
    the ute is lowered to the legal limits wondering if this is causing the extra strain on the joint and is there an aftermarket CV designed compensate for the ute being lowered
    Thanks
    Problemchild
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I have heard that a 4 point camber/toe kit will put extra strain on these drive line components, so if he has one, then a switch two a 2 point kit could help, although failure this quickly surely could not be completely due to a camber kit.
    When you say 'legal limits' how low are we talking?
    Basically, the lower you go, the less 'give' in the spring and that 'give' is transferred to strain on these driveline components.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    Lowering the car pushes the CV joint inwards and can cause binding during suspension travel.
    This can also damage the diff if it bottoms out inside the CV Joints.
    Also fitting second hand shafts from a standard height car puts them into a different working area inside the joint where the balls have not been working before hence cause stress from different wear patterns.
    Welcome to the joys of lowering a car too much.
    I spose he can think himself lucky his diff has not let go yet, but if the shafts are bottoming out its only a matter of time before his diff is rooted as well.
    Fitting a camber kit can stand the tyres up a bit more and lengthen the shafts in their working area but thats only a bandaid fix realy, do its have much camber on the rear end?
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Just to confirm what you are saying... What has failed the "Tail shaft" OR... rear "CV joint" as they are two different things???
    The "Tail Shaft" is the thing that comes off the bearbox to the diff while the CV joints go from the center diff to the rear wheel hubs/disks.
    VX s pac manual
    Nov 2009
    South West Sydney
    im no expert iv been told its the tailshaft CV joint, im sure he ment the cv joint
    CV8 Monaro & VE SV6
    Sep 2009
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    VX s pac manual
    Nov 2009
    South West Sydney
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    The correct terminolgy for the one on the tail shaft is: Uni Joint and/or donut coupling and there are at least two in our modern vehicles, with I think from the VN onwards ther are 3.... a camber kit will do nothing for this.
    The correct terminology for the one between the diff and the rear disk/hubs is: Rear CV joint/Rear stub axels... and a camber kit will help a little, tell him to stop doing 9000rpm burnouts and driving like a twat as this is what fcuks up these.
    VX s pac manual
    Nov 2009
    South West Sydney
    we've all tried telling him to stop driving like a fwit (converted FORD driver) anyway he got it to a machanic today there going to try to source shortened tailshafts for it next week
LinkBacks (?)
  1. 15-01-2012, 08:01 PM
  1. Joint Number
    By alien in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-05-2009, 06:50 PM
  2. ball joint?
    By TWOJZ in forum General
    Last Post: 25-06-2008, 09:11 PM
  3. CV Joint
    By caldonia in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-11-2007, 02:50 PM
  4. CV joint problems
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2005, 06:05 PM
  5. Uni Joint
    By midnight.outlaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2004, 04:19 PM
