Results 1 to 7 of 7
Thread: Replaced thermostat
    2009 VE SS UTE
    Jun 2009
    Emerald
    Default Replaced thermostat
    I just replaced my stock thermostat with the MACE 82 degree thermostat
    I took the old one out and put the new one in and bolted the housing to the block again
    But there is water around the edges of the gasket when the car is on.
    Do I need to replace the gasket or what would I need to do to stop it from leaking??
    I put some gasket maker around the join but it still slowly builds up with water
    Thank in advance
    Vy Executive S1 Wagon
    Dec 2010
    Melb
    Hi all.
    Its always a good idea to change the gasket aswell. I only use a little bit of sealant with the gasket....some guys dont.
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    what temp is the standard thremo stat?
    bad idea changing it to a lower one.
    I did a quick google search and found some interesting coments. See what you think: Pay particular attention to "Evil-Twin" He's meant to be a retired GM engineer who worked on the LS1 cooling system.
    http://forums.corvetteforum.com/c5-t...placement.html
    http://forums.corvetteforum.com/1557142528-post8.html
    http://forums.corvetteforum.com/1554901004-post64.html
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I would assume that a lower temp thermostat would make your engine run a bit cooler. These are designed to run at the factory temp. So don't know if it's a good idea to do what you've done?
    VY SII HBD Calais L67
    Dec 2006
    Running a 10degree cooler thermo is quite acceptable. It will not mess with the tune or throw trouble codes at all.
    Always replace a gasket when it is removed
    VYII Calais L67
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Yeah a gasket costs a couple of bucks tops, so it is worth the time putting it in to save on the hasstle later.
    From what I gathered from what 'evil twin' said was that the LS1 runs best in terms of performance and engine life between 82 to 92 degrees celcius.
    Assuming that the Buick block has a bit more tolerance, you could say that the lower temp thermostat won't harm the engine too much.
    'Evil twin' also said that he uses the lower temp thermostat during the warmer months of the year, so from this you could say that it would work best for your car during the warmer months, while the factory thermostat that is meant for your car, should be used in the cooler months of the year.
    I too believe it is bad to thrash your car when it hasn't warmed up because it wears out your engine more and you don't get the same performance that you do with an engine at proper operating temperature.
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    82 degree thermostat in a ecotec is no problem at all.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  1. [Buick] What needs to be replaced
    By -ToM- in forum V6 Development And Modification
    Last Post: 10-06-2009, 10:19 AM
  2. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  3. Can it be replaced
    By Just_Ice in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2006, 10:04 AM
  4. Can it be replaced???
    By _Mukas_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 04:50 PM
  5. VR 4th gearbox replaced..
    By HKS88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2006, 02:00 PM
