Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: VY LS1 Runnning rough, Backfiring. What is wrong?
    Nov 2004
    Default VY LS1 Runnning rough, Backfiring. What is wrong?
    My car all of a sudden (ls1 vy2 Calais) when you start her up for the first time.. it runs like a dream! Perfect! Get to where your goin turn it off, sweet as! If you leave the car sit off for about half hour. Then turn it on. It coughs, chokes, splutters, backfires, feels like 5 cylinders have just shut down.. That happens for about 2 - 3 minutes then it runs fine. Well almost fine.. still has a slight roughness to it. WTF is that?
    Spark plugs - Done
    Leads 8mm - Done
    O2 Sensors - Done
    I have no clue!... What do you think? Car has done 97,000kms. ..Johno
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Nov 2004
    I have read that on a few forums. Should do it to rule it out, but. always runs premium shell V. should I try some injector cleaner? or seeing as though the car is nearly 100,000ks should i just replace them?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by crazzy-johno View Post
    I don't think it's your injectors. Would be looking at other things first. I run injector cleaner through my V6 periodically to keep them clean. Imo 100,000 k shouldn't warrant new injectors yet. Sorry, can't help with other ideas, I've got intermittent starting probs myself at the moment.....DOH!
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    ...still has a slight roughness to it. WTF is that?
    ... is the reason why I said injectors.
    My toy has almost 130,000 and gave the injectors a proper clean @ the 110,000k service... made a huge difference, smoother idle, better economy, better acceleration and well worth the money.
    Nov 2004
    Smile
    OK! nice! I'll put some injector cleaner through it anyway still this problem is really started to bug me aye.. loosing all respect for the car over it
    Nov 2004
    typing this with greasy hands.. just pulled apart the throttle body for somethin to do .. and really.. should find the inside coated with (thick oil)
    Nov 2004
    engine check light finally came on when it started it shit.. so hopefully track down a scan tool. Cause the people at holden do not give me a warm and fuzzy feeling
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    also check your leads are all pushed in. mine did this a few days ago and i found #2 lead was arcking on the side. pushed it in abit and fixed the problem
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Sounds like leaky injector/s. When you park fuel leaks into the cylinder and fouls the plug/s but eventually cleans itself up when driving.
    Code will probably be for misfire.
    Silver Certified.
    Nov 2004
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Not really, to be cleaned and tested properly you need the proper equipment.
    This is a test/clean rig..
    Silver Certified.
    Nov 2004
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Dunno may leak till u lose enough fuel pressure to stop it then the fuel evaporates overnight or runs down the cylinder walls into the oil pan and the combustion chamber dries out.
    Silver Certified.
  15. #15
    Nov 2004
    Nov 2004
    Thank for that thought Ricey. so should i be looking more at injector or maybe seals?
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Not mine just googled the image haha
    But you can see the tubes for flow testing etc and the bath is for ultrasonic cleaning of the injectors.
    Silver Certified.
  18. #18
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Injector itself, may not be the issue here, just one possibility...
    Silver Certified.
  19. #19
    Nov 2004
    ahhh gota love google! Nah i get ya thanks heaps for a the possibility though! Cause after doin o2, plugs, or leads. i had no idea where to begin
  20. #20
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Replace the fuel filter. I had the same issue, chassed it for ages did everything you've mentioned and more. $15 fuel filter and it goes fine.
  21. #21
    Nov 2004
    I'll give the fuel filter a go.. cause im poor at the moment ive replaced the fuel filter about 20,000 ago but i cant remember one thing... when you pull the clips off the actual filter. will the fuel run out of the lines? or just what ever is left in the filter?
  22. #22
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  23. #23
    Nov 2004
    well ill give the fuel filter ago this arvo for shiz giggles. Wheres a good place in Brissy to get injectors done?????
  24. #24
    Nov 2004
    Quote Originally Posted by soop View Post
    Replace the fuel filter. I had the same issue.
    did you have exactly the same problem??? rough running on a hot start then it would smooth out?
  25. #25
    Nov 2004
    Some thing else of noticed! Something it is doing constantly! While cruising at 80kmh the revs sit on about 1100. When you start to accelerate... it reva from 1100 to 1400 and when is gets between 1400 and 1450... I don't know how to describe it.. it bombs out, like its lost all back pressure. I'm pretty sure (HOPING) that solving 1 problem will solve the other. Exhaust has been checked and crossed off the possibilities list.
LinkBacks (?)
  1. 08-01-2011, 07:19 PM
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. VX Backfiring (LPG)
    By Fonix in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2010, 11:38 PM
  3. thermo runnning 24/7 how to hook up properly
    By vrcalais5ltr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2009, 01:16 AM
  4. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  5. black wire runnning along RCA's???
    By semi in forum Car Audio
    Last Post: 09-10-2005, 11:07 PM
